  3. Hierarchical Top-Down CPF flow
  • Subscribers 95
  • Views 15757
Schriek
Schriek over 8 years ago
Using the hierarchical partitioning flow, I want to create an individual power domain for each partition, which can be turned off.
I've been reading the Innovus user guide "Multiple Supply Voltage Top-Down Hierarchical Flow", but it is rather vague.
As specified I've used 'savePartition' to generate CPF files for each block and for the top-level design.
In the Block-Level CPF Generation chapter, the following is mentioned; "Creates the power domains referenced by the block-level CPF files", weird how it refers to block-level CPF while generating the block-level.
Secondly, in the Top-Level CPF Generation chapter, the following is mentioned "Defines each block-level boundary power domain information through create_power_domain -boundary_ports." generated from the chip-level CPF. However, the generated top-level do not contain these definitions.
Hence the question, how should the chip-level CPF be defined? Currently, I create power domains for each partition after 'definePartition' using read_power_intent/commit_power_intent followed by timing budgeting and partitioning. The block-level CPF generated for a partition contains only the default power-domain, which is not as expected since a different power-domain was specified for the partition (I.e. the partition does not have the right globalConnection)
Thanks.
