  3. Real Nets not Annotated
  • Subscribers 95
  • Views 18781
lapig
lapig over 8 years ago
I am having a lot of difficulty with a flip chip Area IO design. In the design, the IO cell with pin PAD is connected to a BUMP using fcRoute (wide top level metal, low resistance). When I run report_annotated_parasitics command I can see all of my real nets are annotated except for the 131 bi-directional top level nets connected PAD to BUMP. Is there a way to debug why these nets are not annotated?
  • Chetan B S
    Chetan B S over 8 years ago
    Have you done proper extraction? Do you see any issues while reading the spef?
  • Kari
    Kari over 8 years ago
    Check your extraction settings and the extraction log. Make sure SPECIALNETS are getting extracted. They should be.
