  3. Issues with Verify Connectivity on Soc Encounter
  • Subscribers 95
  • Views 15618
BilalBenam
BilalBenam over 8 years ago
I have somme issues with Veriffy Connectivity on Soc Encounter. Actually when I run veriffy connectivity I have somme violations on pad rings (ring_VDD and ring_GND) as Open.
I do the connect global net as following:
globalNetConnect ring_VDD -type pgpin -pin {vdd} -all -override -verbose
globalNetConnect ring_GND -type pgpin -pin {gnd} -all -override -verbose
globalNetConnect ring_GND -type tielo -all -override -verbose
globalNetConnect ring_VDD -type tiehi -all -override -verbose
globalNetConnect ring_VDD -type pgpin -pin {VDD} -all -override -verbose
globalNetConnect ring_VDDE -type pgpin -pin {VDDE} -all -override -verbose
globalNetConnect ring_GND -type pgpin -pin {GND} -all -override -verbose
globalNetConnect ring_GNDE -type pgpin -pin {GNDE} -all -override -verbose
globalNetConnect ring_A0SRC -type pgpin -pin {A0SRC} -all -override -verbose
globalNetConnect ring_A1SRC -type pgpin -pin {A1SRC} -all -override -verbose
globalNetConnect ring_A2SRC -type pgpin -pin {A2SRC} -all -override -verbose
globalNetConnect ring_A3SRC -type pgpin -pin {A3SRC} -all -override -verbose
globalNetConnect ring_A4SRC -type pgpin -pin {A4SRC} -all -override -verbose
globalNetConnect ring_A5SRC -type pgpin -pin {A5SRC} -all -override -verbose
globalNetConnect ring_A6SRC -type pgpin -pin {A6SRC} -all -override -verbose
globalNetConnect ring_TRIGGER -type pgpin -pin {TRIGGER} -all -override -verbose
globalNetConnect ring_BOOST -type pgpin -pin {BOOST} -all -override -verbose
globalNetConnect ring_REFIO -type pgpin -pin {REFIO} -all -override -verbose
do you have somme ideas on these violation and Can you pleas help me to fix these.
Thank you
    The reason your post was blocked was because the spam detection was triggered by the repeated text within it. I allowed the post through after reviewing it.
    I'll leave it to somebody who participates in this forum to answer though!
  • Kari
    Kari over 8 years ago
    it's hard to tell without seeing the violation. your globalNet commands look ok on the surface...
