  3. Issues with nanoroute Soc Encounter
  • Subscribers 95
  • Views 15861
BilalBenam
BilalBenam over 8 years ago
when I am doing nanoroute with soc encounter, i have my I/O nets not routed to the PADs Pins but when I do veriffy connectivity, I don't have violations in these I/O nets.
When I check the wires of the I/O net, they are not routed to the pin pad and just stop routing near from it.
does anyone has an ideas why nanoroute does not route the I/O net to pads and how I can fix that.
Thank you for your response,
Bilal,
Ps: With Trial route the I/Os net are routes to the Pins Pads.
  • Chetan B S
    Chetan B S over 8 years ago
    Hi Bilal,
    Can you kindly check on this -
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nW44EAE&pageName=ArticleContent&sq=005d0000001T5z4AAC_2018863851307
    Chetan B S
  • Kari
    Kari over 8 years ago
    It's hard to tell exactly what situation you are describing... do you mean IO cell PAD pins to bumps are not getting routed, or core-facing IO cell pins?
  • DesmondM
    DesmondM over 8 years ago
    Hi Bilal!
    I have the same issue. Have you solved it?
