  3. Innovus: import hard-macros placement from open-access layout...
  • Subscribers 94
  • Views 18351
Innovus: import hard-macros placement from open-access layout view with some design hierarchy
Pacher Luca
Pacher Luca over 8 years ago
Dear all,
I'm trying to benefit from OA interoperability between Innovus and Cadence IC (Virtuoso) environments for a digital-on-top mixed-signal design. In short, during floorplan I would like to import into Innovus the pre-placement of some analog macros as prepared into the Virtuoso environment. I know that this can be done with the oaIn command,
oaIn libName cellName viewName [-filter {block_insts blockages boundary fixed_core_insts floorplan pad_insts pin_shapes regions regular_routing special_routing}] [-net { netnames }]
This works out-of-the-box only for a flat design in which analog macros are instantiated at top-level, e.g. top/PLL_INST etc.
Indeed, in my case an additional level of logical design hierarchy is part of the design e.g. top/analog/PLL_INST and we cannot flatten the design hierarchy. With this configuration the oaIn command doesn't work anymore, because the analog macro top/analog/PLL_INST in the Verilog gate-level netlist is not found in the corresponding layout view, which instantiates just a PLL design with instance name PLL_INST.
I tried to build with OA layout views a physical hierarchy reflecting the same logical hierarchy I need, i.e. I created a top-level floorplan layout top, instantiating an analog layout that further instantiates the PLL block with instance name PLL_INST but oaIn run on this doesn't recognise the PLL_INST anymore.
Is there the possibility to hierarchical import instances placement from OA into Innovus ?
p.s. I alredy well know that I can place all my instances with the placeInstance command, but in this way any change done in the OA placement would automatically reflect in Innovus, which is faster since I have more than 50 analog macros to place in the design.
Regard
Luca
