  3. How to fix certain Routing?
  • Subscribers 95
  • Views 14885
Mahmoud Dagher
Mahmoud Dagher over 8 years ago
In my place&route implementation in SoC Encounter, I'm placing certain instances and fix their positions by the command placeInstance -fixed , then I route between them manually by long close metals with minimum DRC (It's intentional for my task). The problem is that when I continue the implementation (placing) the standard cells and (optimizing) Design, some of those connections are removed. Is there a way to fix those metal wires I drew manually so they are still connected till the end after all different steps?
  • Chetan B S
    Chetan B S over 8 years ago +2
    Hi Mahmoud, You will need to mark all the wires of such nets as fixed. You can use dbGet commands Regards, Chetan B S
  • Chetan B S
    Hi Mahmoud,
    Chetan B S
    • Vote Up +2 Vote Down
