  3. ERROR with loadLefFile in innovus
  • Subscribers 95
  • Views 19989
Suryansh Singh
Suryansh Singh over 8 years ago
Hello guys,
I am using loadLefFile command in innovus version 17.11. I am trying to give the files LEF files using variables. In one variable I have provided the complete path to my tech LEF and there is another variable that for cell LEFs. For Eg.
loadLefFile $tech_lef_path $cell_lef_path
tech_lef_path-  points to the tech LEF
cell_lef_path - A string of paths to all the cell lefs to be used.
But I guess that loadLefFile is treating the entire string in cell_lef_path as a single path and obviously it would not find such a path. Does anyone have a solution for this?
  • Chetan B S
    Chetan B S over 8 years ago
    Hi Suryansh,
    Please try by splitting the commands as follows:
    loadLefFile $cell_lef_path
  • Suryansh Singh
    Suryansh Singh over 8 years ago in reply to Chetan B S
    Thanks for the reply. I had already tried that. In this what would happen is :
    loadLefFile $tech_lef_path  would work fine as the variable $tech_lef_path has just one path to my tech lef but,
     loadLefFile $cell_lef_path would not work as it has multiple cell lefs specified. I don't want to load each of these lefs separately.
    For more clarity, my cell_lef_path holds a value like "PATH_TO_CELL_LEF1 PATH_TO_CELL_LEF2 PATH_TO_CELL_LEF3...... ". THe loadLefFile command tries to look for the entire string as a single path.
    I did find a solution for myself but I am not completely satisfied with it. I used the following command :
    eval "loadLefFile $cell_lef_path"
    I believe there could be a better solution for this.
    Regards
    Suryansh Singh
  • Kari
    Kari over 8 years ago in reply to Suryansh Singh
    according to the docs, that should work, however this is a really outdated way to read in your design. Check the user guide for methods to read in the design.
