  3. report_timing after clock tree synthesis shows the same...
  • Subscribers 95
  • Views 19551
report_timing after clock tree synthesis shows the same clock to be ideal on capture flop while propagated on the launch flop
Gyan1623
Gyan1623 over 8 years ago
Hello Everyone,
After my clock tree synthesis is done, I use "report_timing" command to report the timing paths. I see some of the clocks in the design to be ideal on the capture path while being propagated on the launch path. Could there be some setting I am missing which has resulted into this? Below is one of the failing paths:
Path 219: VIOLATED (-2.235 ns) Setup Check with Pin digtop_scan_inst/dsp_top_inst/ucdsp_subsystem_inst/u_ucdsp_mem_wrapper/u_ucdsp_yram/CLK->WZ
               View: func_QC_MAX_CUSTOM_W_150_1.35_setup
              Group: reg2reg
         Startpoint: (R) digtop_scan_inst/dsp_top_inst/ucdsp_subsystem_inst/u_uCDSP/inst_reg_ACl/reg_val0_reg_25_/clk
              Clock: (R) DSP_CLK
           Endpoint: (R) digtop_scan_inst/dsp_top_inst/ucdsp_subsystem_inst/u_ucdsp_mem_wrapper/u_ucdsp_yram/WZ
              Clock: (R) DSP_CLK
                       Capture       Launch
         Clock Edge:+   12.000        4.000
         Drv Adjust:+    0.432        0.432
        Src Latency:+    3.286        3.995
        Net Latency:+    0.300 (I)    2.436 (P)
            Arrival:=   16.018       10.862
              Setup:-    0.734
        Uncertainty:-    0.300
        Cppr Adjust:+    0.709
      Required Time:=   15.692
       Launch Clock:=   10.862
          Data Path:+    7.065
              Slack:=   -2.235
Please note the above highlighted line which shows the net latency. The clock DSP_CLK is reported to be (I) ideal for capture while it is reported to be (P) propagated for launch path. Have I missed some attribute setting?
  • Gyan1623
    Gyan1623 over 8 years ago in reply to Chetan B S +1
    Hi Chetan, Thanks for your response. The clock propagation used to stop in the capture path after crossing initial few gates. Below settings before reporting the timing helped resolved the issue: reset_clock_tree_latency…
  • Chetan B S
    Chetan B S over 8 years ago
    Please check on any set_clock_latency applied on DSP_CLK
    You can also check the propagation of the clock to the launch and capture flop clock pins to check for any blocking.
    Chetan B S
  • Gyan1623
    Hi Chetan,
    reset_clock_tree_latency *
    reset_clock_latency * -source
    reset_clock_latency -source [get_ports *] -clock [get_clocks *]
    reset_clock_latency -source [get_pins * -hier] -clock [get_clocks *]
    Thanks and Regards,
    Gyan
  • Chetan B S
    Chetan B S over 8 years ago in reply to Gyan1623
    Good to know that it is resolved now.
    Chetan B S
