  3. filter_collection doesn't work whi variable
  • Subscribers 92
  • Views 3224
Andrea Spiezia
Andrea Spiezia over 7 years ago
Hi all,
I'm trying to filter a collection with a value.
# following works, it report the same collection of ports_in but   i_pipppp
set filt_ports_in [filter_collection $ports_in {hierarchical_name !~ i_pippo}]
But if I try:
set my_var i_pippo
set filt_ports_in [filter_collection $ports_in {hierarchical_name !~ $my_var}]
# it doesn't work neither
set filt_ports_in [filter_collection $ports_in {hierarchical_name !~ "$my_var"}]
 HAVE YOU A SUGGESTION?
thanks a lot
  • MikeLW
    MikeLW over 7 years ago
    This is simply a TCL syntax error. You need to understand that in TCL { } are quoting characters, and anything inside them will not be evaluated (unless the command itself evaluates them, as if, foreach, etc. do).
    Try this instead:
    set filt_ports_in [filter_collection $ports_in "hierarchical_name !~ $my_var"]
    and see this for more info:
    www.tcl.tk/.../Tcl.htm
  • Andrea Spiezia
    Andrea Spiezia over 7 years ago in reply to MikeLW
    Thank you very much!
