  3. TCL command substitution seems to be broken in Innovus
  • Subscribers 95
  • Views 23547
ReganActual
ReganActual over 7 years ago
commands that return a collection in Innovus (e.g. get_pins, get_ports, etc.) when used in TCL command substitution return a random hex value (handle to the collection maybe?) instead of the actual command results.
example:
innovus 32> get_pins u_atc_osctest/en_sync/*/*/CP
u_atc_osctest/en_sync/delay_line[0]_ff_pos_u_sync_ff_pos/u_endura_SDFSYNCND2/CP u_atc_osctest/en_sync/delay_line[1]_ff_pos_u_sync_ff_pos/u_endura_SDFSYNCND2/CP
0xa6a
The get_pins command correctly returns the pin names I wanted from my design (good!) and also some garbage hex value (bad).  The hex # increments by 1 for every command I run that returns a collection.
If I try to use the results using the normal tcl sqare-brackets command substitution
innovus 34> create_ccopt_skew_group -name SG_test -sources [get_pins {u_atc_osctest/en_sync/*/*/CP}]
**ERROR: (IMPCCOPT-2057):    Source '0xa6b' for skew group 'SG_test' is not a pin.
It passes the garbage hex value to the command, instead of the actual results.  Note it does not matter what command I pass things to.
innovus 35> set test_list [get_pins  {u_atc_osctest/en_sync/*/*/CP}]
0xa6c
innovus 36> echo $test_list
0xa6c
innovus 37> set test_list [get_pins u_atc_osctest/en_sync/*/*/CP]
0xa6d
innovus 38> echo $test_list
0xa6d
I always get the hex value instead of the actual command result.
This cannot possibly be a behavior that someone actually wanted.
Does anyone know why this happens, and how to make it stop so I can do TCL scripting in a normal way for Innovus.  Thanks.
  • StefanoTraferro
    StefanoTraferro over 7 years ago
    from my experience it depends on how the command is treating its options/arguments. I've seen commands which can handle your example well, but others cannot (as in your case).
    For your specific case, it appears that this option accepts only plain text which you can get using get_attribute, e.g. create_ccopt_skew_group -name SG_test -sources [get_attribute [get_pins {u_atc_osctest/en_sync/*/*/CP}] full_name]
    It's a little bit cumbersome, but it does the job.
  • ReganActual
    ReganActual over 7 years ago in reply to StefanoTraferro
    That did work, thank you.
    Using [get_property ... hierarchical_name] as a wrapper around the [get_pins ...] call also worked.
