  3. Power estimation - Genus
  • Subscribers 94
  • Views 3017
yenass
yenass over 7 years ago
I am using Genus for post-synthesis power estimation, this estimation is based on the use of the lp_asserted_toggle rates and static probability.
The idea is I am wondering due to some results when i used the lp_computed toggle rates and static probability, because
When I build a 8 bit register like 8 DFF flip flops with an asserted clock frequency of 100MHZ (toggle rates=0.2 and static probability=0.5) with inputs asserted to taoggle rates that exceed 0.1 (more than f/2)
I get at the output of the flip flops toggle rates as the inputs for example for 0.15 i got 0.15 for the output, classically the flip flop should suppress the effect of glitch (cases where toggle_rates >0.1 in our case)
I kindly ask you to help to understand this issue well.
Best Regards,
Yenass
