  3. multiple and indepedent clock in the same circuits without...
  • Subscribers 94
  • Views 14765
multiple and indepedent clock in the same circuits without clock domain crossing
olalivier
olalivier over 7 years ago
Hi there,
I wonder if that would be possible to synthesize a circuit with multiple
and independent clock in the same circuit. the circuit is made of the
following items:
+ 32 independent full custom oscillators, each one providing its output
signal as a clock for the next stage
+ 32 independent counters which take as a clock the output of one of the
oscillators mentioned above
+ 1 readout circuit with its own clock that is only working when the
counters are not counting.
The system work as follow. A signal allow all the counters to count
with a clock signal coming from a full custom oscillator. The
oscillation frequency for each oscillator is different because they're
not made the same way and this oscillation frequency may vary according
to temperature, or aging, or some other parameters. Because we know how
long the counting gate has been opened, we can use this device as a
monitor for the parameters of interest. Once the counting gate is
closed, we need to get the value of the counters. for this we use the
readout circuit which has its own (low) clock frequency. I think we can
talk about mutliple clock system without clock domain crossing.
Also, I would like to be able to run the placement in innovus with each
counter being a device of its own and the readout being a cell of it own
too. the small sketch below show exactly what I intend to do.
Thank you for your time and consideration.
Olivier
