  3. Innovus Parasitic Extraction Compatible for Spice Simul...
  • Subscribers 94
  • Views 15690
Innovus Parasitic Extraction Compatible for Spice Simulation
anurans
anurans over 7 years ago
Hi All,
Is it possible to annotate the interconnect parasitics (.spef and .dspf) generated (IQRC) after P&R in Innovus,  with a pre-layout transistor level netlist of standard cells in Virtuoso ? This procedure is bit similar to post-layout STA. Instead of gate level netlist, I wonder whether we can use the interconnect parasitics with transistor level netlist. Instead of doing GDS flow, can we generate accurate timing and power numbers in this way ?
Ranayas
