  3. Stylus flowtool
  • Subscribers 110
  • Views 27145
Stylus flowtool
ccrumpnc
ccrumpnc over 6 years ago
  I wanted to open a discussion on the stylus flowtool.  My purpose is to see if there are users out there who are having success with the tool.  To have some discussions around issues that I am running into and to get a user point of view on the problems I am trying to solve.
  Let's start the conversation with : Is there anyone out there trying to use flowtool?  Do you have a centralized flow, or each user has their own?
Thanks, and I look forward to the conversations...
--Craig Crump
  • DanScientic
    DanScientic over 6 years ago
    I just started using flowtool primarily for Genus and Innovus flows. Looks very power but it is highly design database centric, lots of db calls so you need a good understanding of the available APIs. Two things that may help you debug is that you can use -ide to have a outline view of your flows. - interactive will also help you trace problems. I'll post here if I find any additional useful information.
  • Mun Sing
    Mun Sing over 6 years ago in reply to DanScientic
    Is the flowtool bin Tool dependence?
    Genus has one and Innovus has one... which one is the right one?
  • fdr5sdfer
    fdr5sdfer over 4 years ago
    [deleted]
  • Matt Hutson
    Matt Hutson over 4 years ago
    We have started using flowtool for Innovus (was Foundation flow before).
    However for Tempus I just converted my existing scripts over to stylus(cui). Using convert_legacy_to_common_ui and eval_legacy {}.
    Main reason was I had C/DMMMC options setup in my scripts and it wasn't the easiest to do.
    Also converting commands and getting flowtool working would have been tricky, and the dist.py was not SGE grid yet.
    I imagine will give it another try at some point.
  • wajeh
    wajeh over 4 years ago in reply to fdr5sdfer
    Hi I have also started using flowtool for Genus and Innovus. However I am stuck at defining the rc_tech_lef_file_map in innovus_config.tcl. Which file is the tool expecting here?
    Where do I get this map file?
  • agelababypo
    agelababypo over 4 years ago
    Understanding how to use the top-level module is really difficult.
    1v1 battle  build now gg
