  3. About using Liberate to create .lib for a cell with two...
  • Subscribers 94
  • Views 14963
About using Liberate to create .lib for a cell with two separate outputs.
caoxg
caoxg over 6 years ago
Hello, my name is Hsukang. I want to use Liberate to create a .lib file for the following circuit. This is a scan FF with two separate outputs.   The question is that no matter how I described its function, the synthesis tool said its a manformed scan FF.  Has anyone ever encountered anything like this?How should I describe the function correctly?I found that almost standard flip-flop cells are with only one output Q or have Qn at the same time. Does Liberate support scan flip-flop cells with two separate outputs ?
Thanks.
