  3. Innovus Stylus Common UI
  • Subscribers 94
  • Views 23734
yavuzselim
yavuzselim over 6 years ago
How can I make innovus start with common UI instead of legacy? When I launch Innovus with command "innovus", I get the legacy UI. I have Innovus version 17.11 installed.
Thanks in advance.
  • Dimo M
    Dimo M over 6 years ago
    You can start Innovus in CUI with "innovus -stylus". To see all available options, you can use "innovus -help".
  • yavuzselim
    yavuzselim over 6 years ago in reply to Dimo M
    Right, that worked. However, I got a warning that says I have limited customer testing access. How much of a restriction does that imply? I'm using Genus 17.11 and it generates output files that are only compatible with Stylus UI. Would I have any issues with that?
