  3. How to place pins inside of the edge in Innovus
  • Subscribers 95
  • Views 20926
Archon2019
Archon2019 over 6 years ago
I am doing layout for a mixed-signal circuit in Innovus. I want to create a digital donut style of layout (i.e. put analog circuit in the middle, and circle analog part with digital circuits).
To do that, I need to place some pins inside the edge to connect to analog circuit (as shown in my attachment), but the problems is that I cannot place pins inside the edge by using "pin editor" within Innovus. Any suggestions to place pins inside?
Thank you so much for your time and effort.
  • gundicad2
    gundicad2 over 6 years ago
    Not sure what you mean by 'inside' the pins are always on the inside of a 'block'.  You can specify offsets for pins in X and/or Y distances....I tried a dbget followed by a dbset however there are object types that do not allow dbset to change parameters. Hope this helped a little.
