  3. checkRoute or VerifyConnectivity
  • Subscribers 95
  • Views 20249
Vij Krish
Vij Krish over 6 years ago
Hello Everyone,
I was finishing the layout via Innovus and ran verifyConnectivity followed by checkRoute.
verifyConnectivity was okay and it showed no errors and no warnings, whereas checkRoute showed there are 3 unrouted nets.
When i ran the checkRoute command again immediately, it showed no unrouted/unconnected nets.
Which of these commands should we trust or is this really unrouted nets issue?
Looking forward for a response, thanks in advance.
Vijay
  • gundicad2
    gundicad2 over 6 years ago
    If you can find the net name use selectNet 'name' and see if you have a route segment or via that is missing, may be a weird blockage on a cell pin....sometimes the founry put odd blockages on the std cell or macro pins...hope this helps
  • Dimo M
    Dimo M over 5 years ago
    Hi Vij,
    checkRoute should not be used for verifying connectivity and it will be removed in future versions of Innovus.
    Please use verifyConnectivity/verify_connectivity for checks.
    Dimo
