  3. How to close design in Innovus or remove design from Innovus...
  • Subscribers 94
  • Views 25055
How to close design in Innovus or remove design from Innovus (remains on disk)?
rajinnv
rajinnv over 6 years ago
One way is to exit the tool. I tried a few things but couldn't find such basic command.
  • Dimo M
    Dimo M over 5 years ago
    for debugging you can use the reset_design command (In legacy: freeDesign) -  Innovus Text Command Reference - reset_design
    However, it does not reset the internal state of applications or global settings, so it is not reliable enough to use in a real flow.
    The recommended method is to exit the tool and start a new session.
    Dimo
