  3. Issue when exporting the Innovus layout to Virtuoso
  • Subscribers 94
  • Views 19185
OrangeHalo
OrangeHalo over 6 years ago
Hi all,
I am doing some digital implemtation staff. I used Innovus to do PnR, and export the layout using GDS format to virtuoso.
Problem: All the label layers imported to Virtuoso appear to be drawing layers. As you can see in the figure below:
My thoughts: The mapping file for exporting Innovus layout to GDS format have some problems. Some layer definations(data type?) have errors. The thing is that I don't know how to modify the stream data types in mapping file, and I don't know how to map the purposes in the map file(such as NET, SPNET, PIN, etc.) to the technology file provided by my vendor.
Some additional information: I am using TSMC 0.18um GP technology. My map file and stream layer information are shown below:
========StreamUut Mapping File========
CONT PIN 15 0
CONT LEFPIN 15 0
CONT FILL 15 0
CONT FILLOPC 15 0
CONT VIA 15 0
CONT VIAFILL 15 0
CONT VIAFILLOPC 15 0
METAL1 NET 16 0
METAL1 SPNET 16 0
METAL1 PIN 16 0
METAL1 LEFPIN 16 0
METAL1 FILL 16 0
METAL1 FILLOPC 16 0
METAL1 VIA 16 0
METAL1 VIAFILL 16 0
METAL1 VIAFILLOPC 16 0
METAL1 LEFOBS 16 0
NAME METAL1/NET 16 0
NAME METAL1/SPNET 16 0
NAME METAL1/PIN 16 0
NAME METAL1/LEFPIN 16 0
VIA12 PIN 17 0
VIA12 LEFPIN 17 0
VIA12 FILL 17 0
VIA12 FILLOPC 17 0
VIA12 VIA 17 0
VIA12 VIAFILL 17 0
VIA12 VIAFILLOPC 17 0
METAL2 NET 18 0
METAL2 SPNET 18 0
METAL2 PIN 18 0
METAL2 LEFPIN 18 0
METAL2 FILL 18 0
METAL2 FILLOPC 18 0
METAL2 VIA 18 0
METAL2 VIAFILL 18 0
METAL2 VIAFILLOPC 18 0
METAL2 LEFOBS 18 0
NAME METAL2/NET 18 0
NAME METAL2/SPNET 18 0
NAME METAL2/PIN 18 0
NAME METAL2/LEFPIN 18 0
VIA23 PIN 27 0
VIA23 LEFPIN 27 0
VIA23 FILL 27 0
VIA23 FILLOPC 27 0
VIA23 VIA 27 0
VIA23 VIAFILL 27 0
VIA23 VIAFILLOPC 27 0
METAL3 NET 28 0
METAL3 SPNET 28 0
METAL3 PIN 28 0
METAL3 LEFPIN 28 0
METAL3 FILL 28 0
METAL3 FILLOPC 28 0
METAL3 VIA 28 0
METAL3 VIAFILL 28 0
METAL3 VIAFILLOPC 28 0
METAL3 LEFOBS 28 0
NAME METAL3/NET 28 0
NAME METAL3/SPNET 28 0
NAME METAL3/PIN 28 0
NAME METAL3/LEFPIN 28 0
VIA34 PIN 29 0
VIA34 LEFPIN 29 0
VIA34 FILL 29 0
VIA34 FILLOPC 29 0
VIA34 VIA 29 0
VIA34 VIAFILL 29 0
VIA34 VIAFILLOPC 29 0
METAL4 NET 31 0
METAL4 SPNET 31 0
METAL4 PIN 31 0
METAL4 LEFPIN 31 0
METAL4 FILL 31 0
METAL4 FILLOPC 31 0
METAL4 VIA 31 0
METAL4 VIAFILL 31 0
METAL4 VIAFILLOPC 31 0
METAL4 LEFOBS 31 0
NAME METAL4/NET 31 0
NAME METAL4/SPNET 31 0
NAME METAL4/PIN 31 0
NAME METAL4/LEFPIN 31 0
VIA45 PIN 32 0
VIA45 LEFPIN 32 0
VIA45 FILL 32 0
VIA45 FILLOPC 32 0
VIA45 VIA 32 0
VIA45 VIAFILL 32 0
VIA45 VIAFILLOPC 32 0
METAL5 NET 33 0
METAL5 SPNET 33 0
METAL5 PIN 33 0
METAL5 LEFPIN 33 0
METAL5 FILL 33 0
METAL5 FILLOPC 33 0
METAL5 VIA 33 0
METAL5 VIAFILL 33 0
METAL5 VIAFILLOPC 33 0
METAL5 LEFOBS 33 0
NAME METAL5/NET 33 0
NAME METAL5/SPNET 33 0
NAME METAL5/PIN 33 0
NAME METAL5/LEFPIN 33 0
VIA56 PIN 39 0
VIA56 LEFPIN 39 0
VIA56 FILL 39 0
VIA56 FILLOPC 39 0
VIA56 VIA 39 0
VIA56 VIAFILL 39 0
VIA56 VIAFILLOPC 39 0
METAL6 NET 38 0
METAL6 SPNET 38 0
METAL6 PIN 38 0
METAL6 LEFPIN 38 0
METAL6 FILL 38 0
METAL6 FILLOPC 38 0
METAL6 VIA 38 0
METAL6 VIAFILL 38 0
METAL6 VIAFILLOPC 38 0
METAL6 LEFOBS 38 0
NAME METAL6/NET 38 0
NAME METAL6/SPNET 38 0
NAME METAL6/PIN 38 0
NAME METAL6/LEFPIN 38 0
NAME COMP 220 0
COMP ALL 221 0
DIEAREA ALL 222 0
===========.tf stream layer file===
streamLayers(
;( layer streamNumber dataType translate )
( ("ref" "drawing") 0 0 t )
( ("PWELL" "drawing") 1 0 t )
( ("NWELL" "drawing") 2 0 t )
( ("NWELL" "pin") 2 6 t )
( ("DIFF" "drawing") 3 0 t )
( ("DIFF" "dummy") 3 1 t )
( ("DIFF" "drain") 3 3 t )
( ("DIFF" "pin") 3 6 t )
( ("OD2" "drawing") 4 0 t )
( ("N3V" "drawing") 5 0 t )
( ("PIMP" "drawing") 7 0 t )
( ("NIMP" "drawing") 8 0 t )
( ("EPLY" "drawing") 9 0 t )
( ("BPLY" "drawing") 10 0 t )
( ("PDIFF" "drawing") 11 0 t )
( ("NDIFF" "drawing") 12 0 t )
( ("POLY1" "drawing") 13 0 t )
( ("POLY1" "dummy") 13 1 t )
( ("POLY2" "drawing") 14 0 t )
( ("CONT" "drawing") 15 0 t )
( ("METAL1" "drawing") 16 0 t )
( ("METAL1" "dummy") 16 1 t )
( ("METAL1" "slot") 16 2 t )
( ("METAL1" "BSL") 16 100 t )
( ("METAL1" "BSD") 16 101 t )
( ("VIA12" "drawing") 17 0 t )
( ("METAL2" "drawing") 18 0 t )
( ("METAL2" "dummy") 18 1 t )
( ("METAL2" "slot") 18 2 t )
( ("PAD" "drawing") 19 0 t )
( ("PAD" "BSL") 19 100 t )
( ("BPI" "drawing") 20 0 t )
( ("VIA67" "drawing") 21 0 nil )
( ("METAL7" "drawing") 22 0 nil )
( ("METAL7" "dummy") 22 1 nil )
( ("METAL7" "slot") 22 2 nil )
( ("VTM_P" "drawing") 23 0 t )
( ("VTM_N" "drawing") 24 0 t )
( ("VTDP" "drawing") 25 0 t )
( ("VTDN" "drawing") 26 0 t )
( ("VIA23" "drawing") 27 0 t )
( ("METAL3" "drawing") 28 0 t )
( ("METAL3" "dummy") 28 1 t )
( ("METAL3" "slot") 28 2 t )
( ("ESD" "drawing") 30 0 t )
( ("VIA34" "drawing") 29 0 t )
( ("METAL4" "drawing") 31 0 t )
( ("METAL4" "dummy") 31 1 t )
( ("METAL4" "slot") 31 2 t )
( ("VIA45" "drawing") 32 0 t )
( ("METAL5" "drawing") 33 0 t )
( ("METAL5" "dummy") 33 1 t )
( ("METAL5" "slot") 33 2 t )
( ("RPO" "drawing") 34 0 t )
( ("P2V" "drawing") 35 0 t )
( ("PTDIODE" "drawing") 37 0 t )
( ("METAL6" "drawing") 38 0 t )
( ("METAL6" "dummy") 38 1 t )
( ("METAL6" "slot") 38 2 t )
( ("VIA56" "drawing") 39 0 t )
( ("METAL1" "pin") 40 0 t )
( ("METAL1" "BSP") 40 100 t )
( ("METAL2" "pin") 41 0 t )
( ("METAL3" "pin") 42 0 t )
( ("METAL4" "pin") 43 0 t )
( ("DMEXCL" "dummy4") 150 4 t )
( ("SLTEXCL" "dummy4") 158 4 t )
( ("METAL5" "pin") 44 0 t )
( ("DMEXCL" "dummy5") 150 5 t )
( ("SLTEXCL" "dummy5") 158 5 t )
( ("METAL6" "pin") 45 0 t )
( ("DMEXCL" "dummy6") 150 6 t )
( ("SLTEXCL" "dummy6") 158 6 t )
( ("METAL7" "pin") 46 0 nil )
( ("DMEXCL" "dummy7") 150 7 nil )
( ("SLTEXCL" "dummy7") 158 7 nil )
( ("POLY1" "pin") 47 0 t )
( ("POLY1" "lvs") 47 1 t )
( ("HRI" "drawing") 48 0 t )
( ("BJTDUMMY" "drawing") 49 0 t )
( ("PSUB2" "drawing") 50 0 t )
( ("HOTWL" "drawing") 51 0 t )
( ("RWDUMMY" "drawing") 52 0 t )
( ("RWDUMMY" "drawing1") 52 1 t )
( ("VCDUMMY" "drawing") 53 0 t )
( ("RPDUMMY" "drawing") 54 0 t )
( ("RPDUMMY" "drawing1") 54 1 t )
( ("HVPRDMY" "drawing") 54 2 t )
( ("RP4TDUMMY" "drawing") 54 3 t )
( ("EXCL" "drawing") 55 0 t )
( ("DIODUMMY" "drawing") 56 0 t )
( ("SDI" "drawing") 58 0 t )
( ("TEXT" "drawing") 59 0 t )
( ("DRCDUMMY" "drawing") 60 0 t )
( ("N2V" "drawing") 61 0 t )
( ("prBoundary" "drawing") 62 0 t )
( ("marker" "error") 63 0 t )
( ("LMARK" "drawing") 63 1 t )
( ("LW" "drawing") 63 2 t )
( ("IP" "drawing") 63 63 t )
( ("marker" "warning") 64 0 t )
( ("DPDUMMY" "drawing") 65 0 t )
( ("PLDUMMY" "drawing") 66 0 t )
( ("CTM2" "drawing") 67 2 t )
( ("CTM3" "drawing") 67 3 t )
( ("CTM4" "drawing") 67 4 t )
( ("CTM5" "drawing") 67 5 t )
( ("CDUMMY" "drawing") 68 0 t )
( ("RMDUMMY" "drawing") 69 0 t )
( ("RMDUMMY" "drawing1") 69 1 t )
( ("RMDUMMY" "drawing2") 69 2 t )
( ("RMDUMMY" "drawing3") 69 3 t )
( ("RMDUMMY" "drawing4") 69 4 t )
( ("RMDUMMY" "drawing5") 69 5 t )
( ("RMDUMMY" "drawing6") 69 6 t )
( ("CELLIMP" "drawing") 70 0 t )
( ("PV_P" "drawing") 71 0 t )
( ("PV_N" "drawing") 72 0 t )
( ("BASE_N" "drawing") 250 1 t )
; ( ("BTC" "drawing") 73 0 t )
; ( ("VCC" "drawing") 74 0 t )
( ("RODUMMY" "drawing") 75 0 t )
; ( ("ESEXCL" "drawing") 76 0 t )
; ( ("CPDUMMY" "drawing") 77 0 t )
( ("PDIMP" "drawing") 78 0 t )
( ("PUIMP" "drawing") 79 0 t )
( ("CELLBRC1" "drawing") 80 0 t )
( ("BLBRC2" "drawing") 81 0 t )
( ("DNW" "drawing") 82 0 t )
( ("P1W" "drawing") 83 0 t )
( ("P1R" "drawing") 84 0 t )
( ("SAC" "drawing") 85 0 t )
( ("C1" "drawing") 86 0 t )
( ("C2" "drawing") 87 0 t )
( ("DPITCH" "drawing") 88 0 t )
( ("PLMIDE" "drawing") 89 0 t )
( ("1TDMY" "drawing") 90 0 t )
( ("HNVT" "drawing") 91 0 t )
( ("PO1" "drawing") 92 0 t )
( ("FLASH" "drawing") 94 0 t )
( ("FGT" "drawing") 96 0 t )
( ("HVII" "drawing") 97 0 t )
( ("HVNW" "drawing") 99 0 t )
( ("FLASH" "LLNW") 100 0 t )
( ("FLASH" "ODLL") 101 0 t )
( ("WELLBODY" "drawing") 103 0 t )
( ("MICO" "drawing") 106 0 t )
( ("VICO" "drawing") 107 0 t )
( ("OVERLAP" "drawing") 110 0 t )
( ("MTPCELL" "drawing") 115 0 t )
( ("PSUB" "drawing") 116 0 t )
( ("MCEL" "drawing") 122 0 t )
( ("SEALRING" "drawing") 126 0 t )
( ("LDDMY" "drawing") 127 0 t )
( ("CASDMY" "drawing") 127 1 t )
( ("ULLNW" "drawing") 128 0 t )
( ("ULLNLDD" "drawing") 128 1 t )
( ("NTN" "drawing") 129 0 t )
( ("DRC2DUMMY" "drawing") 130 0 t )
( ("CTMDUMMY" "drawing") 131 0 t )
( ("CTMDUMMY" "drawing2") 131 10 t )
( ("CTMDUMMY" "drawing3") 131 15 t )
( ("CTMDUMMY" "drawing4") 131 20 t )
( ("CTMDUMMY" "drawing1") 131 21 t )
( ("RHDUMMY" "drawing") 132 0 t )
( ("IMSOR" "CELLMV") 133 0 t )
( ("IMSOR" "CELLH") 133 1 t )
( ("IMSOR" "NPS") 133 2 t )
( ("IMSOR" "PL") 133 3 t )
( ("IMSOR" "GM") 133 4 t )
( ("IMSOR" "RM") 133 5 t )
( ("IMSOR" "BM") 133 6 t )
( ("IMSOR" "ML") 133 7 t )
( ("IMSOR" "PPS") 133 8 t )
( ("IMSOR" "NMOS_VT") 133 9 t )
( ("IMSOR" "CI") 133 10 t )
( ("IMSOR" "CIRPO") 133 11 t )
( ("IMSOR" "GM1") 133 12 t )
( ("IMSOR" "GM2") 133 13 t )
( ("IMSOR" "CELLD") 133 14 t )
( ("IMSOR" "MS") 133 15 t )
( ("IMSOR" "LS") 133 16 t )
( ("IMSOR" "YM") 133 17 t )
( ("IMSOR" "CM") 133 18 t )
( ("IMSOR" "MM") 133 19 t )
( ("IMSOR" "E_ML") 133 20 t )
( ("IMSOR" "BGP") 133 21 t )
( ("IMSOR" "BGN") 133 22 t )
( ("IMSOR" "CELL_TX") 133 23 t )
( ("IMSOR" "CELL_RS") 133 24 t )
( ("IMSOR" "CAP_IMP") 133 25 t )
( ("IMSOR" "CELL_TX2") 133 26 t )
( ("IMSOR" "MP") 133 27 t )
( ("IMSOR" "DPW") 133 28 t )
( ("IMSOR" "CF3D") 133 29 t )
( ("IMSOR" "SEL") 133 30 t )
( ("IMSOR" "FLD") 133 31 t )
( ("IMSOR" "NPS2") 133 32 t )
( ("RLPPDUMMY" "drawing") 134 0 t )
( ("NOOPC" "drawing") 135 0 t )
( ("ESD1DUMMY" "drawing") 136 0 t )
( ("ESD2DUMMY" "drawing") 137 0 t )
( ("VARDUMMY" "drawing") 138 0 t )
( ("VARDUMMY" "drawing1") 138 1 t )
( ("VARDUMMY" "drawing2") 138 2 t )
( ("VARDUMMY" "drawing3") 138 3 t )
( ("VARDUMMY" "drawing4") 138 4 t )
( ("INDDUMMY" "drawing") 139 0 t )
( ("INDDUMMY" "drawing1") 139 1 t )
( ("P3V" "drawing") 140 0 t )
( ("HV" "SH_P") 141 1 t )
( ("HV" "SH_N") 141 2 t )
( ("HV" "SH_PO") 141 3 t )
( ("HV" "HVIO") 141 4 t )
( ("HV" "OW") 141 5 t )
( ("HV" "DMYLD") 141 31 t )
( ("HV" "LDPW") 141 32 t )
( ("HV" "PDD") 141 49 t )
( ("HV" "NDD") 141 50 t )
( ("HV" "DPW") 141 51 t )
( ("HVDMY" "drawing") 141 52 t )
( ("PA24DMY" "drawing") 141 60 t )
( ("NLD24DMY" "drawing") 141 61 t )
( ("RS3TDMY" "drawing") 141 62 t )
( ("NLVT" "drawing") 141 63 t )
( ("HVTN" "drawing") 142 0 t )
( ("HVTP" "drawing") 143 0 t )
( ("SBDDMY" "drawing") 144 0 t )
( ("SGDUMMY" "SBDDMY") 144 1 t )
( ("MOMDMY" "drawing") 145 0 t )
( ("MOMDMY" "drawing1") 145 1 t )
( ("MOMDMY" "drawing2") 145 2 t )
( ("MOMDMY" "drawing3") 145 3 t )
( ("MOMDMY" "drawing4") 145 4 t )
( ("MOMDMY" "drawing5") 145 5 t )
( ("MOMDMY" "drawing6") 145 6 t )
( ("VIAEXCL" "dummy1") 146 1 t )
( ("VIAEXCL" "dummy2") 146 2 t )
( ("VIAEXCL" "dummy3") 146 3 t )
( ("VIAEXCL" "dummy4") 146 4 t )
( ("VIAEXCL" "dummy5") 146 5 t )
( ("VIAEXCL" "dummy6") 146 6 t )
( ("VIAEXCL" "dummy7") 146 7 t )
( ("VIAEXCL" "dummyf") 146 15 t )
( ("CODEP" "drawing") 148 0 t )
( ("DMP2V" "drawing") 149 0 t )
( ("DMEXCL" "dummy1") 150 1 t )
( ("DMEXCL" "dummy2") 150 2 t )
( ("DMEXCL" "dummy3") 150 3 t )
( ("DMEXCL" "dummyf") 150 15 t )
( ("ODBLK" "dummy") 150 20 t )
( ("POBLK" "dummy") 150 21 t )
( ("METAL1" "boundary") 151 0 t )
( ("METAL2" "boundary") 152 0 t )
( ("METAL3" "boundary") 153 0 t )
( ("METAL4" "boundary") 154 0 t )
( ("METAL5" "boundary") 155 0 t )
( ("METAL6" "boundary") 156 0 t )
( ("METAL7" "boundary") 157 0 t )
( ("SLTEXCL" "dummy1") 158 1 t )
( ("SLTEXCL" "dummy2") 158 2 t )
( ("SLTEXCL" "dummy3") 158 3 t )
( ("MD" "pin") 159 0 t )
( ("RFDUMMY" "drawing") 160 0 t )
( ("RFDUMMY" "drawing1") 160 1 t )
( ("RFDUMMY" "drawing2") 160 2 t )
( ("VIA12" "boundary") 161 0 t )
( ("VIA23" "boundary") 162 0 t )
( ("VIA34" "boundary") 163 0 t )
( ("VIA45" "boundary") 164 0 t )
( ("VIA56" "boundary") 165 0 t )
( ("VIA67" "boundary") 166 0 t )
( ("VIAD" "drawing") 167 0 t )
( ("MD" "drawing") 168 0 t )
( ("MD" "dummy") 168 1 t )
( ("MD" "slot") 168 2 t )
( ("CBD" "drawing") 169 0 t )
( ("CBD" "BSL") 169 100 t )
( ("UBM" "drawing") 170 0 t )
( ("UBM" "BSL") 170 100 t )
( ("CB2" "drawing") 177 0 t )
( ("CB2" "BSL") 177 100 t )
( ("LOGO" "drawing") 178 0 t )
( ("NBL" "drawing") 179 0 t )
( ("HVOX" "drawing") 180 0 t )
( ("WBDMY" "drawing") 183 0 t )
( ("DMN2V" "drawing") 184 0 t )
( ("CODEC" "drawing") 185 0 t )
( ("PSDMY" "drawing") 187 0 t )
( ("RV" "drawing") 188 0 t )
( ("RV" "BSL") 188 100 t )
( ("PPI" "drawing") 189 0 t )
( ("AP" "drawing") 189 1 t )
( ("AP" "BSL") 189 100 t )
( ("AP" "pin") 189 101 t )
( ("AP" "BSP") 189 102 t )
( ("ZERO_VTP" "drawing") 196 0 t )
( ("LEVEL" "drawing") 200 1 t )
( ("PBL" "drawing") 200 2 t )
( ("PPLG" "drawing") 200 3 t )
( ("NDN" "drawing") 200 4 t )
( ("NLV" "drawing") 200 5 t )
( ("BSOX" "drawing") 200 6 t )
( ("PXBA" "drawing") 200 7 t )
( ("NXBA" "drawing") 200 8 t )
( ("PEMO" "drawing") 200 9 t )
( ("PSIC" "drawing") 200 10 t )
( ("PLV" "drawing") 200 11 t )
( ("NEM" "drawing") 200 12 t )
( ("PEM" "drawing") 200 13 t )
( ("UBM" "pin") 207 1 t )
( ("LVGDMY" "drawing") 209 1 t )
( ("SRAM" "dummy1") 231 1 t )
( ("SRAM" "dummy2") 231 2 t )
( ("SRAM" "dummy3") 231 3 t )
( ("ESD3DUMMY" "drawing") 234 0 t )
( ("FW" "drawing") 235 0 t )
( ("PMDMY" "drawing") 236 0 t )
( ("OTP" "drawing") 237 0 t )
( ("HVPSW" "drawing") 241 0 t )
( ("TSV" "drawing") 251 0 t )
( ("TSV" "pin") 251 1 t )
( ("TSV" "dummy") 251 2 t )
( ("TSV_CB" "drawing") 252 0 t )
( ("TSV_PPI" "drawing") 253 0 t )
( ("TSV_PPI" "pin") 253 1 t )
( ("LUPWDMY" "drawing") 255 1 t )
( ("FFCDMY" "drawing") 255 2 t )
( ("CONT" "boundary") 0 0 nil )
( ("CONT" "net") 0 0 nil )
( ("METAL1" "net") 0 0 nil )
( ("METAL2" "net") 0 0 nil )
( ("METAL3" "net") 0 0 nil )
( ("METAL4" "net") 0 0 nil )
( ("METAL5" "net") 0 0 nil )
( ("METAL6" "net") 0 0 nil )
( ("METAL7" "net") 0 0 nil )
( ("VIA12" "net") 0 0 nil )
( ("VIA23" "net") 0 0 nil )
( ("VIA34" "net") 0 0 nil )
( ("VIA45" "net") 0 0 nil )
( ("VIA56" "net") 0 0 nil )
( ("VIA67" "net") 0 0 nil )
( ("boundary" "drawing") 0 0 nil )
) ;streamLayers
Thanks in advance.
Best,
OrangeHalo
