  3. Max_tran violation not resolved in INNOVUS
  • Subscribers 94
  • Views 17270
Andrea Spiezia
Andrea Spiezia over 6 years ago
there is a way to know why INNOVUS optDesign -postroure is not able to solve a max_tran violation ?
  • Dimo M
    Dimo M over 5 years ago
    Hi Andrea,
    with the following switch you can increase the verbosity of optDesign w.r.t. failing reasons for DRVs:
    setOptMode -detailDrvFailureReason true (CUI: set_db opt_detail_drv_failure_reason true)
    If you have many violated nets you might want to increase the maximum number of nets reported using this switch:
    setOptMode -detailDrvFailureReasonMaxNumNets 100 (CUI: set_db opt_detail_drv_failure_reason_max_num_nets 100)
    The reasons for the failing will be written in reports under timingReports/drvFailureReason.
    This is how the report for a net can look like this:
    Net 1: FE_PDN0_out_c
    Viol: -0.2746
    MultiBuffering: Skipped due to DontTouch Net
    Dimo
