  3. Joules RTL power analysis can not recognize defined par...
  • Subscribers 94
  • Views 15126
Joules RTL power analysis can not recognize defined parameter
yy777
yy777 over 6 years ago
I used RTL to analysis power with Joules but there was an error occur when i generated db file.
The error information: Invalid Verilog syntax is parsed, or unsupported Verilog syntax is encountered.
I defined a parameter as below:
`define VTTBL(RWR_ADR) \
nxt_trans_req = 1;\
nxt_trans_addr = PWR_ADR;\
nxt_trans_type = 0;
And i used it as below:
case(tsm_st)
TSM_IDLE: begin
     if(tsm_trig) begin
     `VTTBL(16'h0)
      nxt_tsm_st = TSM_CH0_TRN_CFG;
     end
end
The question is ,does Joules not support such macro definition usage? My version is v19.13-s003_1
  • yy777
    I'm waiting for an answer ~~~
