  3. Problem in reporting set_data_check in Genus 19
  • Subscribers 94
  • Views 15636
dbellix
dbellix over 6 years ago
I am experiencing some issues in reporting the outcome of the SDC constraint set_data_check. Briefly, I am trying to constraint the delay between two input pins of a combinational gate, with the classic -from -to syntax. Genus is able to recognize correctly the constraint in the SDC but I cannot get anything useful from the report_timing command, neither specifying directly the path. As specified in the user guide, I am also setting enable_data_check to true before importing the design and timing_disable_non_sequential_checks is set to false.
Do you have any suggestion?
dbellix
