  3. InnoVus Sroute IMPSR-2405
  • Subscribers 94
  • Views 13856
Sirpa
Sirpa over 6 years ago
I am running sroute in Innovus ang get warning : (IMPSR-2405): Specified pin WIRECELL_EXT_CSF_FC_LIN ANAIO does not match db pin.
The power and ground nets are not correctly connected to pads, so I suspect this warning has something to do with it. How to correct this?
I am using INNOVUS v19.11
Also I have found a error report on this Innovus version: CCMPR02290918 sroute fails to connect some stripes to pad pins
Is there a workaround to this ?
Could this actually be the root cause to the warning?
BR. Sirpa
