  3. generateCapTbl command fails in INNOVUS because "Poly layer...
  • Subscribers 96
  • Views 3126
generateCapTbl command fails in INNOVUS because "Poly layer is not defined in pcs file"
Massiomo
Massiomo over 5 years ago
I am running the following command in INNOVUS:
generateCapTbl -ict <ict file> -output <captable file>
to convert a .ict file to a captable file. I am getting the warning: "IMPEXT-6014 error Poly layer is not defined in the PCS file, M1 will see substrate directly" followed by the Error "POLY height is not correct" and the Error "M1 height is not correct". I looked through my .ict file and it looks good, the poly layer has gate_forming_layer set to true, so I am confused as to why the poly layer isn't being recognized.
