  3. Innovus - Poly alignment issue
  • Subscribers 94
  • Views 3227
shreyas kv
shreyas kv over 5 years ago
Hi
After the placement stage in the innovus, I could see the polys of the placed standard cells misaligned. Please see the screenshot below. This is causing many DRC violations when the GDS is imported in virtuoso . What could be causing this issue and how can we solve this?  Any help is greatly appreciated.
Thanks in advance
regards
Shreyas
  • Dimo M
    Dimo M over 5 years ago
    Hi Shreyas,
    you can check if the cells are legally placed in Innovus with check_place/checkPlace.
    You can also check if the standard cell descriptions in the LEF and the GDS have the same contents and origin.
    BR
    Dimo
