  3. Restrict buffer use for a particular sub block while routing...
  • Subscribers 94
  • Views 14516
Restrict buffer use for a particular sub block while routing using INNOVUS
RohithSivakumar
RohithSivakumar over 5 years ago
Is it possible to route clock tree with up to 8x buffers for everything except one particular sub block where buffers larger than 4x are not used?
  • Dimo M
    Dimo M over 5 years ago
    Hi Rohith,
    you cannot define CTS buffers on submodule basis. You can, however, define buffer cells for clock trees and power domains.
    So if you define a separate power domain for this hierarchical instance, you can control the CTS buffers within the hierarchy. You might want to define the clock ports
    as dont_touch, so that CTS does not clone it.
    Alternatively, you can define a clock tree for this subhierarchy, but for this you will have to add a buffer to serve as a source for the new clock tree.
    You can use the root attribute cts_buffer_cells / cts_inverter_cells (In legacy UI: set_ccopt_property buffer_cells) to define the buffer cells for the different power domains.
    Please refer to the Innovus user guide and Text command reference for further information about the usage of these attributes.
    Dimo
