  3. Innovus hold-time optimization in the presence of synch...
  • Subscribers 94
  • Views 15973
Innovus hold-time optimization in the presence of synchronizers
DusanR
DusanR over 5 years ago
Innovus somehow detects FF synchronizers in the circuit (which is good) and disables InPlaceOptimization of synchronizer nets. However, it seems that negative hold time slacks of non-optimized nodes prevent to meet the desired hold time slack in the rest of the circuit. My project is based on 180 nm technology and I target 0.2 ns hold time slack. In the presence of synchronizer nets with ~ -0.2 ns hold time slack, the best positive hold time slack after 'opt_design -post_route -setup -hold' is reported in the range of 0.03 ns.
Are there any suggestions how to implement circuits with synchronizers ?
Is there any way to exclude disabled nets from the optimization  ?
dusan.raic@fe.uni-lj.si
or
raic.dusan@gmail.com
  • Dimo M
    Dimo M over 5 years ago
    Hi Dusan,
    you can try to separate the timing paths ending at these synchronizers into a separate path group to guide the optimizer.
    Please refer to this article for further information about path groups and optimization:  Using the path groups for timing analysis and optimization
    If you do not have an Cadence Online Support account, you can register using your Innovus license host ID.
    You can get the license host ID from a colleague who has registered (they can view it in My Support → My Account & Preferences → My Profile → Manage Host IDs) or you can get the valid Host ID from your system admin.
    Btw, you might want to remove your email address from the post to protect yourself from spam.
    Dimo
  • DusanR
    DusanR over 5 years ago in reply to Dimo M
    Thanks a lot !
