  3. "A mandatory condition failed to be true, Condition: Snz_Nets...
  • Subscribers 95
  • Views 4422
"A mandatory condition failed to be true, Condition: Snz_Nets::sxNetsNet"-error when running "timeDesign" in Innovus
mbrand
mbrand over 5 years ago
we are trying to route a custom 2-stage hierarchical design using Innovus using the following tool versions obtained by "innovus -version":
  • Innovus v20.11-s130_1 (64bit) 08/05/2020 15:53 (Linux 2.6.32-431.11.2.el6.x86_64)
  • NanoRoute 20.11-s130_1 NR200802-2257/20_11-UB (database version 18.20.512) {superthreading v2.9}
  • AAE 20.11-s008 (64bit) 08/05/2020 (Linux 2.6.32-431.11.2.el6.x86_64)
  • CTE 20.11-s059_1 () Aug  2 2020 05:46:30 ( )
  • SYNTECH 20.11-s028_1 () Aug  1 2020 06:14:27 ( )
  • CPE v20.11-s013
  • IQuantus/TQuantus 19.1.3-s260 (64bit) Thu May 28 10:57:28 PDT 2020 (Linux 2.6.32-431.11.2.el6.x86_64)
  • OA 22.60-s011 Tue Jun 16 12:27:00 2020
  • SGN 20.10-d001 (01-Jun-2020) (64 bit executable, Qt5.9.0)
  • RCDB 11.15.0
  • STYLUS 20.10-p011_1 (06/03/2020 04:47 PDT)
When Innovus is running "timeDesign -postRoute -prefix route" it aborts with the following error:
 83 ERROR (Cpp-2) :
 84 ----------------------   FATAL   ----------------------
 85 A mandatory condition failed to be true at line 1348 of file snzcaps.h.
 86 Condition: Snz_Nets::sxNetsNet()
 87 [SimplexCppLib::AssertFailureMsg]
 88 -------------------------------------------------------
I am having trouble to figure out what causes the error / understanding what the actual issue is since I am rather new to the field and the Cadence tool chain.
Did someone encounter a similar issue before, can clarify or maybe just point me to a more detailed error description? Much appreciated!
This is the generated log file (~5kB):
Fullscreen 4401.extr.0.parallel_processing_0.log Download
Cadence Innovus(TM) Implementation System.
Copyright 2020 Cadence Design Systems, Inc. All rights reserved worldwide.
Version:	v20.11-s130_1, built Wed Aug 5 15:53:11 PDT 2020
Options:	-log extLogDir/IQuantus_28-May-2021_18:06:00_16864_pX60rK/extr.WPPA_wrapper.0.parallel_processing_0.log -noMultiCpuLicCheckout -DP -x 0001B027D7... -edpId 0 -edpHost codesign86 -edpPort 46511 -nowin -nologv -init /scratch-local/brand/synthesis/processor_array/4x4/dual_port_pe_blackbox/tcpa-22nm-flow/cdns_pnr/.16864_soce_slave_0
Date:		Fri May 28 18:06:38 2021
Host:		codesign86 (x86_64 w/Linux 4.15.0-143-generic) (8cores*16cpus*Intel(R) Core(TM) i9-7960X CPU @ 2.80GHz 22528KB)
OS:		Unsupported OS as /etc does not have release info
License:
		Running innovus (-x) with Innovus_Impl_System capability.
		Extra license Innovus_20nm_Opt
The soft stacksize limit is either up to the hard limit or larger than 0.2% of RAM. No change is needed.
**INFO:  MMMC transition support version v31-84
<CMD> set_global _enable_mmmc_by_default_flow      $CTE::mmmc_default
<CMD> suppressMessage ENCEXT-2799
<CMD> getVersion
<CMD> getVersion
Sourcing file "/scratch-local/brand/synthesis/processor_array/4x4/dual_port_pe_blackbox/tcpa-22nm-flow/cdns_pnr/.16864_soce_slave_0" ...
<CMD> setLimitedAccessFeature FlipFlopMergeAndSplit 1
INFO: You have enabled new technology 'FlipFlopMergeAndSplit' that has been internally qualified at Cadence but has only limited customer testing. You are encouraged to work with Cadence directly to qualify your usage and make sure it meets your needs before deploying it widely. Final production licensing of this feature is subject to change.
<CMD> setLimitedAccessFeature flow_effort_xtreme 1
INFO: You have enabled new technology 'flow_effort_xtreme' that has been internally qualified at Cadence but has only limited customer testing. You are encouraged to work with Cadence directly to qualify your usage and make sure it meets your needs before deploying it widely. Final production licensing of this feature is subject to change.
EDP: start server on codesign86:49993
Fri May 28 18:06:52 2021: Successfully connected to the master.
sending server data to client codesign86 49993 0 11053
Started sub-activity 0 out of 10 for Extraction...
INFO (EXTIQUANTUS-101) :
  Integrated Quantus - 64-bit Parasitic Extractor - Version 19.1.3-s260
INFO (EXTIQUANTUS-103) : Starting at 2021-May-28 18:06:53 (2021-May-28 16:06:53 GMT).
INFO (EXTIQUANTUS-159) : Loading technology data from file:
/tmp/innovus_temp_16864_codesign86_brand_fka78x/iqrc_tmp_16864_H5clvh/.qrctemp/CceRCGEN0tch11053
INFO (EXTIQUANTUS-289) : Loading RCgen extraction models from file:
INFO (EXTIQUANTUS-345) : Checking Command/Tech/License Files.
INFO (EXTIQUANTUS-105) : Starting design extraction....
INFO (EXTIQUANTUS-282) : Checking Command/Tech Files.
INFO (EXTIQUANTUS-277) : Manufacturing Data Information :-
  DEF/GDS file
    does NOT contain MetalFill data.
  Techfile
    does     contain WEE data.
    does NOT contain Erosion data t=f( density )
    does     contain R(w) data.
    does     contain R(w, s) data.
    does     contain TC(w) data.
    does     contain T/B enlargement data.
    does     contain Floating Metal Fill models.
INFO (EXTIQUANTUS-287) : Capacitance Models Information :-
 ICECAPS models are not available.
 RCgen   models are     available.
 This IQuantus session uses RCgen models.
INFO (EXTIQUANTUS-286) : RCs effects computed for this session include :-
 MetalFill        : OFF
 WEE Effects      : rc
 Erosion Effects  : n/a t=f( density )
 T/B Enlargements : ON
 R(w) Effects     : ON
 R(w,s) Effects   : ON
 TC(w) Effects     : ON
Some effects indicate n/a because of non-availability of relevantinput data
(or) requested to be off (and/or) usage of older Icecaps models.
ERROR (Cpp-2) :
Ending at 2021-May-28 18:06:58 (2021-May-28 16:06:58 GMT).
  Executed by:           brand
  Execution host:        codesign86
  Run duration:          00:00:05 CPU time, 00:00:05 clock time
  Memory used:           4930 Mb
  Warning messages:      0
  Error messages:        0
  Fatal error messages:  1
Exit code 1.
IQuantus exited with errors.
**ERROR: (IMPEXT-1211):	Extraction engine failed with the message: Child process failed.
Sub-activity 0 of Extraction Completed.
*** Memory Usage v#2 (Current mem = 2622.195M, initial mem = 1037.719M) ***
*** Message Summary: 0 warning(s), 1 error(s)
--- Ending "Innovus" (totcpu=0:00:18.6, real=0:00:30.0, mem=2622.2M) ---
  • Dimo M
    Dimo M over 5 years ago
    what we see in your log file is that timeDesign is calling the extraction engine (IQuantus), which in turn fails with this ambiguous error.
    One thing you can try to do is to try running a newer Innovus version ( I know, I know, the oldest trick in the book ...)
    Innovus 20.11 has IQuantus 19.1.3-s260 compiled into it, while  20.13 has version 20.1.1-s460, which is much newer.
    So if you have access to Innovus 20.13 or 20.14, please try to run with it. There is a chance that there is a fix for this problem.
    If this does not help, it will be probably impossible to solve without a testcase for RnD to look for, so you will have to file a service request.
    Dimo
  • mbrand
    mbrand over 5 years ago in reply to Dimo M
    Thank you for the suggestion, but apparently we don't have the licenses for the updated Innovus version.
    Then, that leaves me probably no choice, but to file a service request.
