  3. Problem with adding block rings
  • Subscribers 94
  • Views 16402
francispaul
francispaul over 5 years ago
I am making a chip with a single-sided padring (ie not a ring as pads are only on the bottom). I created the floorplan in Innovus, placed macros and added a core ring without any issues. However, when I try to add block rings around the macros I get this error:
**WARN: (IMPPP-4051): Fail to add rings. Gaps among IO cells may exist. Execute command addIoFiller to fill gaps among cells before addRing.
There are no gaps in the IOs and I have run the addIoFiller to make sure, and as expected no fillers are being added, but the error persists. Any idea what the problem might be?
  • Dimo M
    Dimo M over 5 years ago
    can you please share the tool version you are using and how exactly do you invoke the command.
    Dimo
  • francispaul
    francispaul over 5 years ago in reply to Dimo M
    Hi Dimo,
    I am using INNOVUS_20.11.000.
    My macro for which I am trying to create the block ring is abutted to the top right corner of the core boundary. As the IO pads are only located at the bottom, the right and top core boundary is also the die boundary. To add the block ring: I select the macro in the floorplan. From GUI Power->Power Planning->Add Ring. I enter vdd and gnd as nets. I select Block Rings around->Each selected block and/or group of core rows. Size the block ring with the correct metals, width, spacing and offset. Then go to Advanced Tab and select the left and bottom sides and bottom extensions of the macro only (I unselect all other sides and extensions). I select Wire Group and then click Apply. No ring is created and the terminal shows the aforementioned error.
    Thanks.
  • Dimo M
    Dimo M over 5 years ago in reply to francispaul
    Do you see any other warnings when running the add_rings command ?
    This message tells you that the add_rings failed, but the reason might or might not be related to the gaps between IO cells. It is one common reason why the ring creation failed, so it is added as a suggestion, but the root cause could be something different in your case.
    Dimo
