  3. [Voltus] Why static IR drop require timing window (TWF)...
  • Subscribers 94
  • Views 16998
[Voltus] Why static IR drop require timing window (TWF) file?
huybui
huybui over 5 years ago
Hello all,
I got 2 questions about Voltus static power analysis.
1. Can you help to clarify below concept in Voltus UG:
It quite strange because switching power belong to dynamic power.
2. Why static IR drop check require TWF file? I thought this file is used for dynamic vectorless IR drop check.
Thank you,
Huy
