  3. Voltus extraction error
  • Subscribers 100
  • Views 15810
DBHADU
DBHADU over 4 years ago
Hi All,
i have tried rail analysis on top level and while doing extraction is shows below error and flow is stoped
** ERROR: (VOLTUS_EXTR-1013): Unexpected condition has occurred. Terminating the program execution.
vector::_M_range_check: __n (which is 4294966193) >= this->size() (which is
1)
can anyone help me in this issue
Thanks in advance
  • gfturywe
    gfturywe over 4 years ago
    I have also encountered this error and don't know how to fix it stick merge
    • Vote Up -1 Vote Down
  • marginblurt
    marginblurt over 4 years ago
    Can you explain more detail about the  error?
    basket random
  • DBHADU
    Hi  All,
    main issue behind this error is that tool is not able to see bumps so tool won't proceed further .
    after loading design please cross check if you are able to see bumps correctly , if not please correct this and rerun .
    Deepak
  • arielle95
    arielle95 over 4 years ago in reply to DBHADU
    This error may be due to the sensor.
    basketball
  • Sandynn
    Sandynn over 4 years ago
    This is so hard to deal. I also encounter problem like this.
    Dumpster Rental Cedar City
  • luishamillton
    luishamillton over 4 years ago
    did you fix it?
