  3. [INNOVUS] Performing top level implementation for hierarchal...
  • Subscribers 105
  • Views 7818
[INNOVUS] Performing top level implementation for hierarchal/block IC design ("Bottom Up" approach)
TomBradyVLSI
TomBradyVLSI over 4 years ago
I'm currently trying to perform the "bottom up" block design (hierarchal) approach in Innovus.
It is very challenging to understand how to implement the top-level module.
The User guide states the below:
"After block implementation, physical and timing abstract models (ILM/FlexILM) should be
developed for each block-level design that will be used in the top-level implementation. For the
bottom-up approach, create a top-level floorplan where block-level abstracts are referenced in the
top-level design."
Two questions:
1.) How to create ILM and FlexILM for a design?
2.) Anyone know what "top-level floorplan where block-level abstracts are referenced in the top-level design" means?
  • DimoM
    DimoM over 4 years ago +2
    Hi, you can create ILMs using the write_ilm command for each block. There is a RAK about ILMs here: Interface Logic Model (ILM) flow using Innovus Digital Implementation System 20.1 (CUI) Regarding…
  • DimoM
    Regarding your second question - once you have your blocks and their abstracts, you need to instantiate them somewhere, i.e. in the top level.
    So the user guide tells you that you need to create a floorplan for your top-level design and place the block level abstracts in it.
    -Dimo
    • Vote Up +2 Vote Down
  • henny123
    henny123 over 4 years ago
    Does anyone know the answer to this? heardle
    • Vote Up -1 Vote Down
