  3. Netlist Power Analysis Flow with RTL Stimulus
  • Subscribers 100
  • Views 15145
dariomonti
dariomonti over 4 years ago
Hi all,
I am exploring Joules for the power analysis of a netlist synthesized with Genus. Eventually I want to plot the power activity of a stimulus along with the frames. The .vcd is parsed with the read_netlist command. Then, although a stim#1 is generated with various frames, when "compute_power -mode time_based" is executed it returns: "-time_based option is set for single frame SDB, : using average analysis", resulting in a single framed stimulus.
I suppose that my main proble here is to record the set of frames for the stimulus. In fact, when I do either "compute_power -mode time_based" or also "propagate_activity -mode time_based" the result is that the stimulus has only one frame, preventing the time_based mode to be executed (and therefore executing the average one). I extensively explored the lecture slides, labs, user manuals, command reference and the scripts provided along with the rapid adoption kits, but nothing seems to address such issue.
Here are the script steps to generate elaborated database:
- load technology files (libs, lefs, capt);
- read HDL files;
- elaborate design;
- add sdc constraints;
- write_db elab.db;
Script for power analysis from vcd:
- rtlstim2gate -init $ELAB_JDB -keep_libraries;
- read_netlist;
- read_sdc;
- read_stimulus -frame_count 10 -file dump.vcd;
- compute_power -mode time_based;
From the above script, what I would expect is a stimulus equally separated in 10 timeframe (/stim#1/frame#1/, /stim#1/frame#2/, ... /stim#1/frame#10/), but what I get instead is only /stim#1/frame#1/ and compute_power automatically switches to average mode, preventing me to plot the activity.
Any suggestion or indication is appreciated. Thank you.
Dario
  • jullyjean
    jullyjean over 4 years ago
    My biggest issue here, I believe, is recording the stimulus's set of frames. In fact, when I use "compute power -mode time based" or "propagate activity -mode time based," the stimulus only has one frame, prohibiting the time based mode from being used (and therefore executing the average one). I looked through the lecture slides, laboratories, user manuals, command reference, and scripts that came with the quick adoption kits, but nothing seemed to address the problem. smash karts
  • dariomonti
    SOLVED:
    I was launching Joules through Genus using the common UI. The above mentioned problem is solved by using Joules standalone with the legacy user interface.
  • sddu
    sddu over 4 years ago in reply to dariomonti
    yep. thanks bro octordle
  • mallpremium
    mallpremium over 4 years ago in reply to dariomonti
    Very clearly, It's worked.
    cuphead
  • mattiedaniels12
    mattiedaniels12 over 4 years ago
    Hello, and I hope you enjoy your time spent gaming.
    drift hunters
