  3. [Innovus] report the fanout of ICG
  • Subscribers 99
  • Views 18522
hammercui
hammercui over 4 years ago
I am looking for one way to report the ICG fanout status, below pic is the example of the ICG connection
I could get the fanout count of ICG a :
> sizeof_collection [all_fanout -from a -endpoints_only] , then I will get 100+200+300+3(b,c,d)
Now, I want to get the regs count from a: 100; and b's fanout of regs: 200 and c's fanout of regs :300 respectively.
Any comments will be appreciated
  • hammercui
    + more, actually I am looking for one way to ask tool to stop tracing at the first sub level ICG when I report the fanout from one point
  • DimoM
    DimoM over 4 years ago in reply to hammercui
    all_fanout has the switches  -levels and -pin_levels , which you can use for this purpose.
    -Dimo
  • hammercui
    hammercui over 4 years ago in reply to DimoM
    Thanks Dimo
    But it seems, that the -levels include all kinds of gate, for my case, I hope it by pass all combinational logic ....
  • DimoM
    I see what you mean now.
    The easiest way that comes in mind is to use set_case_analysis on the CP pin of the ICG. Then all_fanout won't trace trough it.
    E.g.
    set_interactive_constraint_modes [get_db constraint_modes .name]
    set_case_analysis 0 b/CP
    # Remove case analysis after that
    reset_case_analysis b/CP
    set_interactive_constraint_modes {}
  • hammercui
    Hi DimoM
    Thanks for your comments, yes, by this way I could get the end point (fanout) count for each ICG, but the limitation is we can not trace the relationship between ICGs
    I mean, I can not trace : ICG a drives b, and b drives c, and c drives d .....
  • hammercui
    hammercui over 4 years ago in reply to hammercui
    Innovus should provide one feature to report the ICG tree, which only include ICG and other sequential cells
