  3. Creating power\ground pins for digital modules
  • Subscribers 104
  • Views 9832
Tom Urkin
Tom Urkin over 4 years ago
Hello all,
I have two digital modules created in Cadence DC tool. When I import them to Virtuoso (as Verilog files) they have no VDD and GND pins. In this case i use VDD! and GND! as the power and ground rails for simulation.
However, I would like to separate the power nets - one module will be fed from DC rail V1 and the second from power rail V2 (each module has it own power nets which are not connected).
For that I need to create power and ground pins for each digital module.
How can do this? Other suggestion are most welcomed.
Thanks!
  • DimoM
    DimoM over 4 years ago
    I assume you are referring to the Cadence Genus tool.
    In this case you will need to define a power intent to get PG pins in your netlist and use write_hdl with -pg switch.
    Exemplary flow (in Legacy UI) :
    read_hdl  ...
    elaborate  ...
    read_power_intent dummy.upf // Reading the Dummy UPF
    apply_power_intent
    commit_power_intent
    syn_gen
    syn_map
    write_hdl -pg <design> >  pg_netlist.v  ;# Write out the netlist with PG nets
    Exemplary content of the upf file:
    set_design_top <design_name>
    upf_version 2.0
    create_supply_port VDD
    create_supply_port VSS
    create_supply_net VDD
    create_supply_net VSS
    connect_supply_net VDD -ports VDD
    connect_supply_net VSS -ports VSS
    create_supply_set SS_VDD -function { power VDD } -function { ground VSS } -function { nwell VDD} -function { pwell VSS }
    create_power_domain PD_VDD -include_scope -supply {primary SS_VDD}
    set_port_attributes -applies_to both -elements . -driver_supply SS_VDD -receiver_supply SS_VDD
    BTW this question belongs to the Logic Design forum.
    -Dimo
  • jaredryan12
    jaredryan12 over 4 years ago
    To obtain PG pins in your netlist, you'll need to use write hdl with the-pg flag and declare a power intent. woodoku
  • moranmc
    moranmc over 4 years ago
    [deleted]
  • albertsilver
    albertsilver over 4 years ago in reply to moranmc
    one should go with no concerns in relations to security loopholes I mean I am very much confident to say that is always top-of-mind when it comes on implementing digital applications using variety of security and data protection. Thanks
