  3. common end point for hold fixes
  • Subscribers 95
  • Views 11344
vkad747
vkad747 over 4 years ago
Hi All,
I am looking for adding delay buf at hold endpoints ,trying to trace out common point,so that i can put a buf at that point to see changes across all violating endpoints,I am stuck at the point ,to get the common point for example 1000 unique endpoints,please share your thoughts on how to approach.
  • DimoM
    DimoM over 4 years ago
    typically Innovus would prioritize putting hold fixing buffers at the endpoints.
    What are you trying to achieve exactly ? Do you see Innovus not fixing certain paths for hold?
    If so, there might be some reasons for it that you need to investigate.  E.g. one thing to try could be to allow hold fixing on the cost of setup time violations with the following command:set_db opt_fix_hold_allow_setup_tns_degradation false
    Also please refer to this article for some general guidelines on fixing hold violations: Recommendations for fixing hold violations in EDI System / Innovus
    You can use SDC commands  such as all_fanin, all_fanout to try to track these endpoints. However, at a design of that size where you have thousands of endpoints in the fanout, I have a hard time imagining that manually finding a solution will work.
    -Dimo
