  3. INNOVUS sroute error: not a CUT LAYER
  • Subscribers 95
  • Views 12756
Bowen Xia
Bowen Xia over 4 years ago
I'm using INNOVUS20.17 to P&R on .13 SiGe BiCMOS technology. The tech lib are converted from LEF file to OA with the lef2oa command. When I'm doing the power planning, the sroute command gives me some error message and leave all the power pins unconnected. It seems that the DB technology information is not properly loaded. How can I debug it? Thanks.
sroute -connect {padPin} -allowJogging 0 -allowLayerChange 0
Begin option processing ...
srouteConnectPowerBump set to false
routeSpecial set to true
srouteConnectBlockPin set to false
srouteConnectConverterPin set to false
srouteConnectCorePin set to false
srouteConnectStripe set to false
srouteFollowCorePinEnd set to 3
srouteFollowPadPin set to false
srouteNoLayerChangeRoute set to true
sroutePadPinAllPorts set to true
sroutePreserveExistingRoutes set to true
srouteRoutePowerBarPortOnBothDir set to true
srouteStraightConnections set to "straightWithDrcClean"
End option processing: cpu: 0:00:00, real: 0:00:00, peak: 3321.00 megs.
Reading DB technology information...
   *ERROR* LAYER Metal2 is not a CUT LAYER
   *ERROR* LAYER Metal1 is not a CUT LAYER
Finished reading DB technology information.
Reading floorplan and netlist information...
Finished reading floorplan and netlist information.
   A total of 2 errors.
  • Bowen Xia
    By the way, the NanoRouter is not affected, all other place and route steps are fine. Only the power routing are missing.
  • DimoM
    DimoM over 4 years ago
    it seems there is a problem that happened during the OA file creation, or while loading the tech information into the database.
    The techOA topics are tricky, it requires expert knowledge. I don't think that it can be solved over the forum.
    It would be best to contact Cadence support to help you with that.
    - Dimo
  • Bowen Xia
    Bowen Xia over 4 years ago in reply to DimoM
    Hello Dimo,
    It turns out that I missed the -useFoundryInnovus and -refLib in the lef2oa step, after re-generating the techOA the problem solved.
    Bowen
