  3. How to grap modules' name
  • Subscribers 95
  • Views 9043
Goddard
Goddard over 4 years ago
I have a question to ask the senior,
I‘d like to split a design into several modules and highlight them separately, but I don't know how to use dbGet to capture the name of the modules , and the software I use is innovus (21).
  • DimoM
    DimoM over 4 years ago
    Hi ,
    you can do this using the Innovus GUI and the Design Browser.
    To invoke the Design Browser choose Tools -> Design Browser, or click the Design Browser icon on the toolbar.
    Once the design browser loads, expand the 'Modules' sub-tree, right click on the hierarchical instance you want to highlight and select Highlight  and the color.
    Alternatively you can highlight the modules in the design with the following command:
    foreach hinst [get_db current_design .local_hinsts ] {highlight -index [incr idx] $hinst}
    Note: Use gui_highlight if you are using CommonUI instead.
    - Dimo
  • Goddard
    Goddard over 4 years ago in reply to DimoM
    Dear Dimo,
    Thanks a lot for your reply, its really helpful to me.
    I am trying to use script to reduce my own rework, so my question might be silly. Now I can get modules at any level by nesting the commands you provide; I wonder if there is an argument for specifying level, or if we need to define a function ourselves?
    I would appreciate it if you could reply when you have time.
  • DimoM
    DimoM over 4 years ago in reply to Goddard
    indeed the get_db command has a -depth attribute, which you can use.
    I would suggest registering for the support site support.cadence.com if you have not done so yet and check the following rapid adoption kit (RAK):
    Common UI (CUI) : Using get_db for Database Access
    The command get_db works in both CommonUI and LegacyUI. If you are in LUI mode, you can also use the dbGet command, which also has a  RAK and many articles, e.g. :
    Database Access with DbTCL
    Also in the text command reference you will find a full description of the command.
    Innovus TCR: get_db
    Innovus TCR: dbGet
    - Dimo
  • Goddard
    Dear Dimo,
    Thanks a lot for your reply, I will follow your advice to learn more about these commands.
    Best wishes,
    Goddard
