  3. how to via on SC pin with diffrient Net name
  • Subscribers 96
  • Views 9397
ArcherGong
ArcherGong over 4 years ago
I have created globalNetconnect on PowerSwitch Global Pin VDDG
  globalNetConnect VDD    -type pgpin -pin VDDG -all
but I can not VIA on that pin from VDD M5 to the PowerSwitch Global VDDG M1 with under command
  editPowerVia -bottom_layer M1 -add_vias 1 -top_layer M5 -net VDD
  • DimoM
    DimoM over 4 years ago
    I suggest you isolate the problem first: Is the globalNetConnect not creating a connection for this pin or is the editPowerVia not dropping a via.
    To check that see if the pin is assigned the right net:
    get_db pg_pin:<design><pin_name>/VSS .net.name   -> Is the net correct ?
    If so, you will have to analyze why is this happening. Otherwise, editPowerVia command is not performing as expected for some reason.
    You can try using the option  skip_via_on_pin , in case the power switch is a standard cell :
    editPowerVia -bottom_layer M1 -add_vias 1 -top_layer M5 -net VDD -skip_via_on_pin {}
    - Dimo
