  3. Cannot load in netlists in Innovus: syntax error?
  • Subscribers 97
  • Views 11827
Zackery
Zackery over 3 years ago
Hi, when I try to load in design to Innovus, it returns error message:
Reading netlist ...
Backslashed names will retain backslash and a trailing blank character.
**ERROR: (IMPVL-209): In Verilog file '../RTL_codes/models_pack.v', check line 7 near the text @ for the issue: 'syntax error'. Update the text accordingly.
Type 'man IMPVL-209' for more detail.
Verilog file '../RTL_codes/models_pack.v' has errors! See above.
*** Memory Usage v#1 (Current mem = 908.020M, initial mem = 290.477M) ***
#% End Load netlist data ... (date=12/13 00:08:57, total cpu=0:00:00.0, real=0:00:00.0, peak res=861.0M, current mem=861.0M)
**ERROR: (IMPVL-902): Failed to read netlist ../RTL_codes/N_term_single_switch_matrix.v ../RTL_codes/models_pack.v ../RTL_codes/N_term_single_tile.v. See previous error messages for details. Resolve the issues and reload the design.
innovus 1>
When I type 'man IMPVL-209', it returns :
IMPVL-209(20.15) IMPVL-209(20.15)
NAME
IMPVL-209
SUMMARY
In Verilog file '%s', check line %d near the text %s for the issue:
'%s'. Update the text accordingly.
DESCRIPTION
This message reports the location of the text causing a warning or
error situation in the input netlist file, which is briefly described
by the last argument text. Update the source text accordingly to
resolve the issue.
IMPVL-209(20.15)
And my code is :
module LHQD1 (input D, E, output reg Q, QN);
always @(*)
begin
if (E == 1'b1) begin
Q = D;
QN = ~D;
end
end
endmodule
What error message mentioned is 'always @(*)', I cannot find where the syntax error is, can you help me?
  • DimoM
    DimoM over 3 years ago
    Hi Zackery,
    Innovus expects to read a structural Verilog-1995 netlist, built with standard cells as leaf cells. You seem to try to read the Verilog models of the standard cells, but Innovus does not need that. Instead, it expects .lib files to get the timing and functionality of each cell.
    -Dimo
  • Zackery
    Zackery over 3 years ago in reply to DimoM
    OK, many thanks
