  3. Innovus Error in Multi-thread Placement
  • Subscribers 95
  • Views 16640
rotic
rotic over 3 years ago
I'm using Innovus 18.10 and there is some error with placement and I could not find out why. The server CPU has 112 cores. Innovus used 64 threads, which was set by "set_multi_cpu_usage -local_cpu 64". The stack size was maximum, set by bash command "ulimit -s unlimited". I once tried running the same tcl script and same design with 16 threads and Innovus completed everything normally.
Here's part of the log file:
@file(par.tcl) 277: place_opt_design
No user sequential activity specified, applying default sequential activity of "0.2" for Dynamic Power reporting.
'set_default_switching_activity' finished successfully.
*** Starting GigaPlace ***
**INFO: user set placement options
root: { place_detail_check_cut_spacing {true} place_global_activity_power_driven {false} place_global_activity_power_driven_effort {standard} place_global_clock_power_driven {true} place_global_clock_power_driven_effort {standard} place_global_cong_effort {high} place_global_place_io_pins {true} place_global_uniform_density {true}}
**INFO: user set opt options
root: { opt_all_end_points {true} opt_area_recovery {true} opt_consider_routing_congestion {auto} opt_fix_fanout_load {true} opt_fix_hold_allow_overlap {auto} opt_honor_density_screen {true} opt_leakage_to_dynamic_ratio {0.2} opt_post_route_area_reclaim {none} opt_post_route_drv_recovery {auto} opt_post_route_setup_recovery {true} opt_power_effort {low}}
#optDebug: fT-E <X 2 3 1 0>
**Info: (IMPSP-307): Design contains fractional 20 cells.
*** Start delete_buffer_trees ***
Multithreaded Timing Analysis is initialized with 64 threads
Info: Detect buffers to remove automatically.
Analyzing netlist ...
Updating netlist
AAE DB initialization (MEM=3170 CPU=0:00:00.2 REAL=0:00:00.0)
*summary: 14621 instances (buffers/inverters) removed
*** Finish delete_buffer_trees (0:00:29.3) ***
**INFO: No dynamic/leakage power view specified, setting up the setup view "PVT_0P63V_100C.setup_view" as power view
** WARN: (VOLTUS_POWR-3212): The 'set_power_analysis_mode -leakage_power_view |-dynamic_power_view|-analysis_view' will be obsolete in 18.20 release. Use 'set_analysis_view -leakage <> | -dynamic <>' to set leakage and dynamic power views.
PVT_0P63V_100C.setup_view PVT_0P77V_0C.hold_view
Power Net Detected:
Voltage Name
0.00V VSS
0.63V VDD
# Design Stage: PreRoute
# Design Name: ChipTop
# Design Mode: 7nm
# Analysis Mode: MMMC OCV
# Parasitics Mode: No SPEF/RCDB
# Signoff Settings: SI Off
0.00V VSS
0.63V VDD
clock_clock(500MHz) CK: assigning clock clock_clock to net axi4_mem_0_clock
Starting Levelizing
2023-Jan-10 22:56:18 (2023-Jan-11 04:56:18 GMT)
2023-Jan-10 22:56:19 (2023-Jan-11 04:56:19 GMT): 10%
2023-Jan-10 22:56:19 (2023-Jan-11 04:56:19 GMT): 20%
2023-Jan-10 22:56:19 (2023-Jan-11 04:56:19 GMT): 30%
2023-Jan-10 22:56:20 (2023-Jan-11 04:56:20 GMT): 40%
2023-Jan-10 22:56:20 (2023-Jan-11 04:56:20 GMT): 50%
2023-Jan-10 22:56:21 (2023-Jan-11 04:56:21 GMT): 60%
2023-Jan-10 22:56:21 (2023-Jan-11 04:56:21 GMT): 70%
2023-Jan-10 22:56:22 (2023-Jan-11 04:56:22 GMT): 80%
2023-Jan-10 22:56:22 (2023-Jan-11 04:56:22 GMT): 90%
Finished Levelizing
2023-Jan-10 22:56:23 (2023-Jan-11 04:56:23 GMT)
Starting Activity Propagation
** INFO: (VOLTUS_POWR-1356): No default input activity has been set. Defaulting to 0.2.
Use 'set_default_switching_activity -input_activity' command to change the default activity value.
2023-Jan-10 22:56:31 (2023-Jan-11 04:56:31 GMT): 10%
2023-Jan-10 22:56:34 (2023-Jan-11 04:56:34 GMT): 20%
Finished Activity Propagation
2023-Jan-10 22:56:43 (2023-Jan-11 04:56:43 GMT)
**Info: max transition density of cached activity is: 1e+09
Deleted 0 physical inst (cell - / prefix -).
Did not delete 207651 physical insts as they were marked preplaced.
INFO: #ExclusiveGroups=0
INFO: There are no Exclusive Groups.
Extracting standard cell pins and blockage ......
Pin and blockage extraction finished
Extracting macro/IO cell pins and blockage ......
No user-set net weight.
Net fanout histogram:
2 : 379071 (63.9%) nets
3 : 89194 (15.0%) nets
4 - 14 : 110401 (18.6%) nets
15 - 39 : 9614 (1.6%) nets
40 - 79 : 3624 (0.6%) nets
80 - 159 : 724 (0.1%) nets
160 - 319 : 115 (0.0%) nets
320 - 639 : 49 (0.0%) nets
640 - 1279 : 1 (0.0%) nets
1280 - 2559 : 0 (0.0%) nets
2560 - 5119 : 0 (0.0%) nets
5120+ : 2 (0.0%) nets
**WARN: (IMPSP-196): User sets both -place_global_uniform_density and -place_global_initial_padding_level options. Overriding -place_global_initial_padding_level to 5.
Options: timingDriven clkGateAware ignoreScan pinGuide congEffort=high gpeffort=medium
Scan chains were not defined.
#std cell=855381 (207651 fixed + 647730 movable) #buf cell=0 #inv cell=64869 #block=535 (0 floating + 535 preplaced)
#ioInst=0 #net=592795 #term=2233984 #term/net=3.77, #fixedIo=0, #floatIo=0, #fixedPin=362, #floatPin=0
stdCell: 855381 single + 0 double + 0 multi
Total standard cell length = 1237.7966 (mm), area = 1.3368 (mm^2)
Average module density = 0.136.
Density for the design = 0.136.
= stdcell_area 5315238 sites (1239939 um^2) / alloc_area 39223032 sites (9149949 um^2).
Pin Density = 0.03756.
= total # of pins 2233984 / total area 59472204.
Identified 64502 spare or floating instances, with no clusters.
Enabling multi-CPU acceleration with 16 CPU(s) for placement
=== lastAutoLevel = 12
Clock gating cells determined by native netlist tracing.
Iteration 1: Total net bbox = 1.760e+07 (1.01e+07 7.51e+06)
Est. stn bbox = 1.959e+07 (1.12e+07 8.39e+06)
cpu = 0:03:37 real = 0:03:37 mem = 4867.4M
Iteration 2: Total net bbox = 1.760e+07 (1.01e+07 7.51e+06)
cpu = 0:00:00.8 real = 0:00:01.0 mem = 4885.2M
*** Finished SKP initialization (cpu=0:03:09, real=0:01:37)***
Iteration 3: Total net bbox = 1.254e+07 (7.39e+06 5.16e+06)
Est. stn bbox = 1.516e+07 (8.79e+06 6.37e+06)
cpu = 0:53:05 real = 0:07:00 mem = 8665.0M
Iteration 4: Total net bbox = 1.946e+07 (1.18e+07 7.63e+06)
Est. stn bbox = 2.445e+07 (1.48e+07 9.62e+06)
cpu = 1:38:56 real = 0:10:09 mem = 10053.8M
Iteration 5: Total net bbox = 1.946e+07 (1.18e+07 7.63e+06)
cpu = 0:00:00.1 real = 0:00:00.0 mem = 10053.8M
Iteration 6: Total net bbox = 2.297e+07 (1.24e+07 1.05e+07)
Est. stn bbox = 3.073e+07 (1.62e+07 1.46e+07)
cpu = 0:49:39 real = 0:04:57 mem = 8770.5M
Iteration 7: Total net bbox = 2.321e+07 (1.27e+07 1.05e+07)
Est. stn bbox = 3.100e+07 (1.64e+07 1.46e+07)
cpu = 0:00:00.8 real = 0:00:01.0 mem = 8537.6M
Iteration 8: Total net bbox = 2.321e+07 (1.27e+07 1.05e+07)
cpu = 0:00:01.1 real = 0:00:01.0 mem = 8537.6M
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus[0x10cee9bb]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus(syStackTrace+0x5a)[0x10ceedb1]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus[0x456ae95]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x14420)[0x14e0a2865420]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus(_ZN8spTiming15DelayCalculator16CellArcDelayIter23calcDelayForLinearModelERKNS0_20CellArcDataPerCornerEd+0x9)[0xa0e4149]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus(_ZN8spTiming15DelayCalculator16CellArcDelayIter4nextEv+0x608)[0xa0f56d8]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus(_ZN8spTiming18DelayUpdateServiceIdE14processCellArcEj+0x4e)[0x9fbc7ee]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus[0x9fdb97b]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus(_ZN8spThread12spThreadPool6WorkerIvE4loopEv+0xc7)[0x99aea97]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/lib/64bit/libnffr.so(execute_native_thread_routine+0x20)[0x14e0a8016b60]
/usr/cadence/INNOVUS/INNOVUS1817/tools.lnx86/innovus/bin/64bit/innovus[0x4814af9]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x8609)[0x14e0a2859609]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x43)[0x14e0a212e133]
gdb
Using: gdb
*** Stack trace:
I google searched the tracing "libc.so.6(clone+0x43)" and "libpthread.so.0(+0x8609)". It looks like to be some problem with memory management.
Is there a way to solve this? What else should I do to let Innovus make use of 64 or even more local threads?
  • rotic
    In addition, there are 256GB RAM. That should be enough for innovus to finish placement.
  • DimoM
    DimoM over 3 years ago
    one idea would be to move to a newer tool version, this way you benefit from all the bug fixes and improvements that were done in the last years.
    At best would be to contact support with this question. It will be very hard to debug a crash over the forum, which happens midway through the placement.
    -Dimo
