  3. Genus standard cells to module
  • Subscribers 97
  • Views 18966
JWMP
JWMP over 3 years ago
Hi, I have a TCL script for synthesizing a full adder (see below).
I am trying to modify the script so that when Genus opens, the schematic represents the circuit in module form.
I don't want to see the standard cell circuits and would like to see something simple. It seems I have gotten this to happen but I am not sure how.
When I source the script below, Genus opens and I get the first schematic (schematics are shown below). Without closing Genus, I source the script again and get the second schematic (preferred one).
What is happening that is causing the schematic to change when I source the script for a second time? How I can set the script such that the second schematic is by default? Thanks!
#### Include TCL utility scripts..
include load_etc.tcl
#### Set up
set DESIGN fulladder
set SYN_EFF medium
set MAP_EFF medium
set DATE [exec date +%m%d.%H%M]
set map_fancy_names 1
set iopt_stats 1
set SYN_PATH "."
set_db lib_search_path /home/transistor
set_db init_hdl_search_path .
set_db information_level 7
set_db library {transistor.lib}
set_db hdl_array_naming_style %s\[%d\]
set_db tns_opto true
read_hdl ./inputs/dig.v
elaborate $DESIGN
puts "Runtime & Memory after 'read_hdl'"
timestat Elaboration
check_design -unresolved
report timing -lint -verbose
#### Synthesizing to generic
set_db syn_generic_effort $SYN_EFF
puts "Runtime & Memory after 'synthesize -to_generic'"
timestat GENERIC
set_db auto_ungroup none
syn_generic
#### Synthesizing to gates
set_db syn_map_effort $MAP_EFF
puts "Runtime & Memory after 'synthesize -to_map -no_incr'"
timestat MAPPED
syn_map
remove_assigns_without_optimization
insert_tiehilo_cells
puts "Runtime & Memory after incremental synthesis"
timestat INCREMENTAL
syn_opt
report area > ./outputs/${DESIGN}_area.rpt
report gates > ./outputs/${DESIGN}_gates.rpt
write_hdl > ./outputs/${DESIGN}.vg
write_sdc > ./outputs/${DESIGN}.sdc
gui_show;
1st Schematic
2nd schematic (preferred)
  • DimoM
    DimoM over 3 years ago
    after synthesis you have a standard cell-based netlist and this is what you will be seeing in Genus.
    When you source the script for the second time, you are elaborating the design anew, creating a second copy of the design in the database. If you look at the Design Browser, you have to see that now there are two designs.
    So what you are looking at is a generic netlist, which is not yet synthesized, hence it is simpler.
    -Dimo
