  3. Segmentation Fault (core dumped) when invoking INNOVUS2...
  • Subscribers 97
  • Views 11762
Segmentation Fault (core dumped) when invoking INNOVUS211
ucemqfa
ucemqfa over 3 years ago
Dear all,
I am trying to run Innovus (v21.11 64bit) on Red Hat 7.9 Linux, the tool tries to run but ultimately a "segmentation fault (core dumped)" message appears. I get the same issue when trying to run it on another machine (with the same tool version and operating system).  I read about this error and it is related to memory access. Could you please provide any information to resolve this issue?
Kind Regards,
Qassam
  • DimoM
    DimoM over 3 years ago
    Hi Qassam,
    please refer to the following article regarding hangs and crashes in Innovus:
    Debugging crash, stack trace, and hang in Innovus/Tempus
    If none of that works, you will have to  contact support. Here in the forum we cannot help with such issues.
    -Dimo
  • ucemqfa
    ucemqfa over 3 years ago in reply to DimoM
    Thanks very much, Dimo! I will check it out.
    Qassam
