  3. Annotating multiple dmmmc sdf files with Xcelium
  • Subscribers 94
  • Views 11460
DaniK
DaniK over 3 years ago
Hi all,
After running STA multi-mode-multi-corners I get more than 20 sdf files. I would like to somehow check all of them without running manually more than 20 times xcelium.
Is there any way of doing this? I was thinking of writing a script that generates different argument files for xcelium. each one of them with a different conditional compilation for the testbench, something like this:
`ifdef SDF_ENABLE_1
initial begin
$sdf_annotate("M40_SSG_hold.sdf.gz",
tb.DUT,,"SSG.log","MAXIMUM");
end
`elsif SDF_ENABLE_2
initial begin
$sdf_annotate("M40_FFG_hold.sdf.gz",
tb.DUT,,"FFG.log","MINIMUM");
end
`elsif SDF_ENABLE_
// etc
`endif
Any other ideas? It is a very basic systemverilog testbench, I just want to check timing violations in the log files.
Thanks in advance,
  • DaniK
    DaniK over 3 years ago +1
    Well, just in case someone comes to this post, I solved it this way. I wrote a little script that runs xcelium with the argument file: #! /bin/bash # load xcelium module add XCELIUM…
  • DaniK
    #!/bin/bash
    # load xcelium
    module add XCELIUM
    # Generate directories
    for i in {1..20}
    do
      mkdir corner_$i
    done
    # Run xcelium in each directory
    for i in {1..20}
    do
      cd corner_$i
      xrun -f ../args -define SDF_ENABLE_$i &
      cd ..
    done
