  3. GDS DBU and Database DBU mismatch
  • Subscribers 95
  • Views 10951
Anas2023a95
Anas2023a95 over 3 years ago
Dear all,
I'm trying to import a layout from Innovus to Virtuoso as a GDS file.
When I export the GDS file from Innovus, the following is shown:
This clearly states that DBU is set to 2000 in the technology file (which I have verified and it is actually 2000 in the .lef file) and the generated GDS file has 2000 units per micron of precision, which sounds good!
However, when I import the GDS file into Virtuoso, the log file shows the following warning:
WARNING (XSTRM-284): DbuPerUU (1000) specified in the technology database or using '-dbuPerUU' is not divisible by the value (2000) set in the GDSII file. This can cause loss in data precision during translation.
It says that there is a mismatch between DBU in GDS (2000) and the tech database (1000)!
I have tried this solution to change the DBU stored for a library but I still have the same warning.
Any idea on how to tackle it?
Many thanks
Anas
  • DimoM
    DimoM over 3 years ago
    Hi Anas,
    to get an answer to a Virtuoso related questions, you can post it in the Custom IC Design section.
    However, given that your database has its precision set to 1000, I think that the easiest solution is to set the same precision when streaming out the data from Innovus with "streamOut -units 1000 ...".
    - Dimo
