  3. Getting error message in Innovus.
  • Subscribers 95
  • Views 11778
anola123
anola123 over 3 years ago
Whenever I am restoring my design, I am getting an error message "ERROR: (IMPTR-2101): Layer M10: Pitch=11520x9 is still less than min width=32000 + min spacing=640".
The maximum defined metal layer in my tech file is till M9. But when I am running the command "generateTracks", it also generates M10. It's not affecting my flow but I just want to is there any solution to remove this error message.
  • DimoM
    DimoM over 3 years ago
    it is strange that Innovus reports anything about a layer that does not exist in your techfile. It should be getting some information about it from elsewhere, it cannot come up with layer definitions by itself.
    Please investigate the inputs you give to it when creating the database you are restoring.
    - Dimo
