  3. Innovus does not route net with non-default rule correc...
  • Subscribers 93
  • Views 5109
Innovus does not route net with non-default rule correctly
FormerMember
FormerMember over 3 years ago
Dear Community
I use the following code in Innovus 21.10 to route a net called "VSE2" that is supposed to be much much wider than the remaining nets
add_via_definition -via_rule via1Array -row_col {3 3} -name via1_3x3
add_via_definition -via_rule via2Array -row_col {3 3} -name via2_3x3
add_via_definition -via_rule via3Array -row_col {3 3} -name via3_3x3
add_via_definition -via_rule via4Array -row_col {3 3} -name via4_3x3
add_ndr -name 1_46w1s -width {MET1 1.46 MET2 1.46 MET3 1.46 MET4 1.46 MET5 1.46 METTP 1.46} -via {via1_3x3 via2_3x3 via3_3x3 via4_3x3} -generate_via
setAttribute -net VSE2 -top_preferred_routing_layer 3 -bottom_preferred_routing_layer 2 -preferred_routing_layer_effort high -non_default_rule 1_46w1s
setNanoRouteMode -routeSelectedNetOnly true -drouteUseMultiCutViaEffort high
selectNet VSE2
routeDesign
This is the output:
Why is the right-hand side not routed correctly? What prevents Innovus from routing the net according to the NDR?
Thank you for any suggestions.
  • FormerMember
    FormerMember over 3 years ago in reply to RamesNaikBhukya +2
    Dear Ramesh Thank you very much for your response. Unfortunately, using -routeStrictlyHonorNonDefaultRule true does not alter the result. I also tried -routeStrictlyHonorNonDefaultRule 1:4 but the result…
  • RamesNaikBhukya
    RamesNaikBhukya over 3 years ago
    Hi Domi,
    Apparently, NDR is soft rule and tool might have seen few benefit in not honouring it.  In order to guide tool to honor NDR strictly, please add the following,
    setNanoRouteMode -routeSelectedNetOnly true -drouteUseMultiCutViaEffort high -routeStrictlyHonorNonDefaultRule true
    Ramesh
  • FormerMember
    Dear Ramesh
    Thank you very much for your response. Unfortunately, using -routeStrictlyHonorNonDefaultRule true does not alter the result. I also tried -routeStrictlyHonorNonDefaultRule 1:4 but the result was the same: wrong vias and the NDR was not honored completely. I scanned the log file for potential problems but I could not find any message or warning that would indicate a problem.
    A quick side note for everyone else reading this: Using -generate_via is actually wrong in this context. It generates new vias based on existing ones, which is not what I want. Omitting this argument yields the correct behaviour in this case.
    • Vote Up +2 Vote Down
