  3. xt-ld.exe cannot find CMSIS DSP library
  • Subscribers 96
  • Views 10906
aravindt
aravindt over 3 years ago
Platform: iMXRT500
SDK: SDK_2_11_1_EVK-MIMXRT595
Xtensa Xplorer IDE version: 8.0.15 Windows
I am trying to link SDK_2_11_1_EVK-MIMXRT595\CMSIS\DSP\Lib\GCC\libarm_ARMv8MMLldfsp_math.a to a DSP application. For this, in Xplorer IDE, I set the following:
Library search path is correct. But then, I still see this linker error:
C:/usr/xtensa/XtDevTools/install/tools/RI-2020.5-win32/XtensaTools/bin/xt-ld.exe: cannot find libarm_ARMv8MMLldfsp_math.a
make[1]: *** [dsp_hello_world_usart_fusionf1] Error 2
Please help.
Thank you,
Aravind.
  • aravindt
    I was linking the wrong library. My objective is to run FFT on DSP instead of using PowerQuad.
    I learned that this could be done through NatureDSP library, and I was able to run naturedsp stock example:
    SDK_2_11_1_EVK-MIMXRT595\boards\evkmimxrt595\dsp_examples\naturedsp
    Library link issue is not relevant anymore.
    Thank you,
    Aravind.
  • vsydoruk
    vsydoruk over 3 years ago
    Hi Aravind,
    I was wondering if you actually found the CMSIS DSP sources for Xtensa DSPs? The only sources  I can find are the NatureDSP ones.
    Thank you,
    Volodymyr
  • aravindt
    aravindt over 3 years ago in reply to vsydoruk
    Hi Volodymyr,
    Thank you for your response.
    I was trying to link the wrong library. Yes, I am using NatureDSP library to exercise FFT functions.
    Please close this issue.
    Best regards,
    Aravind.
  • corpusc
    corpusc over 3 years ago
    I was wondering whether you were able to track down the Xtensa DSP CMSIS DSP source code. The NatureDSP sources are the only ones I can find.
  • vsydoruk
    vsydoruk over 3 years ago in reply to corpusc
    Unfortunately not. It would be nice to get some response from the Cadence members on this forum.
