  3. Issues with generated .spef file using Cadence Innovus
  • Subscribers 94
  • Views 9584
Sanjana Basa
Sanjana Basa over 3 years ago
I have generated synthesized netlist of my verilog design on Synopsys Design Compiler tool. For post layout results, Cadence Innovus tool was used and .spef file was generated. When this .spef file is used in Synopsys Primetime PX tool, some nets and pins are not recognized.
The errors are mentioned in detail in the attached log file.
Fullscreen parasitics_command.log Download
Information: Derived library resistance unit is 1.000000 Kohm (Time unit is 1 ns, and Capacitance unit is 1.000000 pF). (DES-028)
Error: Cannot find net 'dut1/FE_OFN9_n261' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'dut1/FE_OFC9_n261/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'FE_OFN8_n143' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC8_n143/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'dut1/FE_OFN7_i_10' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'dut1/FE_OFC7_i_10/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'dut1/FE_OFN6_i_10' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'dut1/FE_OFC6_i_10/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'dut1/FE_OFC7_i_10/A' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'FE_OFN5_n11' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC5_n11/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'FE_OFN4_n11' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC4_n11/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC5_n11/A' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'FE_OFN3_n10' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC3_n10/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'FE_OFN2_n10' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC2_n10/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'FE_OFN1_n10' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC1_n10/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC2_n10/A' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC3_n10/A' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find net 'FE_OFN0_n10' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC0_n10/Z' in design 'aes_12_comp_masoleh' (PARA-124)
Error: Cannot find port/pin 'FE_OFC1_n10/A' in design 'aes_12_comp_masoleh' (PARA-124)
Information: Merged 3 parallel coupling capacitors to total 0.000109939 pf between file nodes 'key[119]:14' and 'dut1/b9[2]:7'. (PARA-050)
Warning: Coupling capacitor (key[118]:19 FE_OFN0_n10:124 4.94679e-05) on net key[118]\ is grounded because net 'FE_OFN0_n10:124' could not be found (PARA-162)
Warning: Coupling capacitor (key[118]:18 FE_OFN0_n10:125 4.94704e-05) on net key[118]\ is grounded because net 'FE_OFN0_n10:125' could not be found (PARA-162)
Warning: Coupling capacitor (key[118]:15 FE_OFN0_n10:124 3.36389e-05) on net key[118]\ is grounded because net 'FE_OFN0_n10:124' could not be found (PARA-162)
Warning: Coupling capacitor (key[118]:14 FE_OFN0_n10:125 3.36389e-05) on net key[118]\ is grounded because net 'FE_OFN0_n10:125' could not be found (PARA-162)
Warning: Coupling capacitor (key[118]:19  4.94679e-05) on net  \ is grounded because net 'FE_OFN0_n10:124' could not be found (PARA-162)
Warning: Coupling capacitor (key[118]:18  4.94704e-05) on net  \ is grounded because net 'FE_OFN0_n10:125' could not be found (PARA-162)
Warning: Coupling capacitor (key[118]:15  3.36389e-05) on net  \ is grounded because net 'FE_OFN0_n10:124' could not be found (PARA-162)
Warning: Coupling capacitor (key[118]:14  3.36389e-05) on net  \ is grounded because net 'FE_OFN0_n10:125' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:9 dut1/FE_OFN9_n261:368 0.000131921) on net key[112]\ is grounded because net 'dut1/FE_OFN9_n261:368' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:10 dut1/FE_OFN9_n261:366 0.000131921) on net key[112]\ is grounded because net 'dut1/FE_OFN9_n261:366' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:9 dut1/FE_OFN9_n261:366 0.000131921) on net key[112]\ is grounded because net 'dut1/FE_OFN9_n261:366' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:10 dut1/FE_OFN9_n261:367 0.000131921) on net key[112]\ is grounded because net 'dut1/FE_OFN9_n261:367' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:9 dut1/FE_OFN9_n261:364 3.73765e-05) on net key[112]\ is grounded because net 'dut1/FE_OFN9_n261:364' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:10 dut1/FE_OFN9_n261:365 3.73673e-05) on net key[112]\ is grounded because net 'dut1/FE_OFN9_n261:365' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:9  0.000131921) on net  \ is grounded because net 'dut1/FE_OFN9_n261:368' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:10  0.000131921) on net  \ is grounded because net 'dut1/FE_OFN9_n261:366' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:9  0.000131921) on net  \ is grounded because net 'dut1/FE_OFN9_n261:366' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:10  0.000131921) on net  \ is grounded because net 'dut1/FE_OFN9_n261:367' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:9  3.73765e-05) on net  \ is grounded because net 'dut1/FE_OFN9_n261:364' could not be found (PARA-162)
Warning: Coupling capacitor (key[112]:10  3.73673e-05) on net  \ is grounded because net 'dut1/FE_OFN9_n261:365' could not be found (PARA-162)
Warning: Coupling capacitor (key[97]:5 FE_OFN0_n10:280 0.000117042) on net key[97]\ is grounded because net 'FE_OFN0_n10:280' could not be found (PARA-162)
Warning: Coupling capacitor (key[97]:6 FE_OFN0_n10:281 0.000117038) on net key[97]\ is grounded because net 'FE_OFN0_n10:281' could not be found (PARA-162)
Warning: Coupling capacitor (key[97]:5  0.000117042) on net  \ is grounded because net 'FE_OFN0_n10:280' could not be found (PARA-162)
Warning: Coupling capacitor (key[97]:6  0.000117038) on net  \ is grounded because net 'FE_OFN0_n10:281' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3 FE_OFN1_n10:220 2.24188e-05) on net key[66]\ is grounded because net 'FE_OFN1_n10:220' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4 FE_OFN1_n10:221 2.2423e-05) on net key[66]\ is grounded because net 'FE_OFN1_n10:221' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3 FE_OFN1_n10:216 8.24473e-05) on net key[66]\ is grounded because net 'FE_OFN1_n10:216' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4 FE_OFN1_n10:217 8.24516e-05) on net key[66]\ is grounded because net 'FE_OFN1_n10:217' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3 FE_OFN1_n10:334 7.4687e-06) on net key[66]\ is grounded because net 'FE_OFN1_n10:334' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4 FE_OFN1_n10:214 7.47293e-06) on net key[66]\ is grounded because net 'FE_OFN1_n10:214' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3 FE_OFN1_n10:214 2.61595e-05) on net key[66]\ is grounded because net 'FE_OFN1_n10:214' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4 FE_OFN1_n10:215 2.61595e-05) on net key[66]\ is grounded because net 'FE_OFN1_n10:215' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3  2.24188e-05) on net  \ is grounded because net 'FE_OFN1_n10:220' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4  2.2423e-05) on net  \ is grounded because net 'FE_OFN1_n10:221' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3  8.24473e-05) on net  \ is grounded because net 'FE_OFN1_n10:216' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4  8.24516e-05) on net  \ is grounded because net 'FE_OFN1_n10:217' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3  7.4687e-06) on net  \ is grounded because net 'FE_OFN1_n10:334' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4  7.47293e-06) on net  \ is grounded because net 'FE_OFN1_n10:214' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:3  2.61595e-05) on net  \ is grounded because net 'FE_OFN1_n10:214' could not be found (PARA-162)
Warning: Coupling capacitor (key[66]:4  2.61595e-05) on net  \ is grounded because net 'FE_OFN1_n10:215' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3 FE_OFN2_n10:193 0.000138488) on net key[21]\ is grounded because net 'FE_OFN2_n10:193' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4 FE_OFN2_n10:194 0.000138488) on net key[21]\ is grounded because net 'FE_OFN2_n10:194' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3 FE_OFN2_n10:194 0.000125905) on net key[21]\ is grounded because net 'FE_OFN2_n10:194' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4 FE_OFN2_n10:195 0.000125895) on net key[21]\ is grounded because net 'FE_OFN2_n10:195' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:10 FE_OFN2_n10:190 4.94718e-05) on net key[21]\ is grounded because net 'FE_OFN2_n10:190' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:8 FE_OFN2_n10:191 4.94718e-05) on net key[21]\ is grounded because net 'FE_OFN2_n10:191' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:12 FE_OFN2_n10:187 3.81e-06) on net key[21]\ is grounded because net 'FE_OFN2_n10:187' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:11 FE_OFN2_n10:188 3.81e-06) on net key[21]\ is grounded because net 'FE_OFN2_n10:188' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3 FE_OFN8_n143:175 3.77673e-05) on net key[21]\ is grounded because net 'FE_OFN8_n143:175' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4 FE_OFN8_n143:176 3.77762e-05) on net key[21]\ is grounded because net 'FE_OFN8_n143:176' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3 FE_OFN8_n143:177 0.000176253) on net key[21]\ is grounded because net 'FE_OFN8_n143:177' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4 FE_OFN8_n143:167 0.000176262) on net key[21]\ is grounded because net 'FE_OFN8_n143:167' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:10 FE_OFN8_n143:167 1.09936e-05) on net key[21]\ is grounded because net 'FE_OFN8_n143:167' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:8 FE_OFN8_n143:168 1.09848e-05) on net key[21]\ is grounded because net 'FE_OFN8_n143:168' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3 FE_OFN8_n143:165 6.59619e-05) on net key[21]\ is grounded because net 'FE_OFN8_n143:165' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4 FE_OFN8_n143:166 6.59619e-05) on net key[21]\ is grounded because net 'FE_OFN8_n143:166' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3  0.000138488) on net  \ is grounded because net 'FE_OFN2_n10:193' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4  0.000138488) on net  \ is grounded because net 'FE_OFN2_n10:194' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3  0.000125905) on net  \ is grounded because net 'FE_OFN2_n10:194' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4  0.000125895) on net  \ is grounded because net 'FE_OFN2_n10:195' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:10  4.94718e-05) on net  \ is grounded because net 'FE_OFN2_n10:190' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:8  4.94718e-05) on net  \ is grounded because net 'FE_OFN2_n10:191' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:12  3.81e-06) on net  \ is grounded because net 'FE_OFN2_n10:187' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:11  3.81e-06) on net  \ is grounded because net 'FE_OFN2_n10:188' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3  3.77673e-05) on net  \ is grounded because net 'FE_OFN8_n143:175' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4  3.77762e-05) on net  \ is grounded because net 'FE_OFN8_n143:176' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3  0.000176253) on net  \ is grounded because net 'FE_OFN8_n143:177' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4  0.000176262) on net  \ is grounded because net 'FE_OFN8_n143:167' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:10  1.09936e-05) on net  \ is grounded because net 'FE_OFN8_n143:167' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:8  1.09848e-05) on net  \ is grounded because net 'FE_OFN8_n143:168' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:3  6.59619e-05) on net  \ is grounded because net 'FE_OFN8_n143:165' could not be found (PARA-162)
Warning: Coupling capacitor (key[21]:4  6.59619e-05) on net  \ is grounded because net 'FE_OFN8_n143:166' could not be found (PARA-162)
Information: Merged 5 parallel coupling capacitors to total 0.000423253 pf between file nodes 'key[20]:5' and 'kout[20]:24'. (PARA-050)
Error: Invalid capacitor (*3975 2.59481e-05) on net out[120]: Pin 'dut1/f1/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*3912 2.59481e-05) on net out[120]: Pin 'dut1/f1/m2/U3/A' is not connected to net (PARA-044)
Information: Merged 2 parallel coupling capacitors to total 6.59606e-05 pf between file nodes 'out[116]:9' and 'out[114]:16'. (PARA-050)
Error: Invalid capacitor (*4083 2.59515e-05) on net out[112]: Pin 'dut1/f2/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4028 2.59515e-05) on net out[112]: Pin 'dut1/f2/m2/U11/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4189 2.59507e-05) on net out[104]: Pin 'dut1/f3/m4/U32/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4128 2.59507e-05) on net out[104]: Pin 'dut1/f3/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4299 2.59491e-05) on net out[96]: Pin 'dut1/f4/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4236 2.59491e-05) on net out[96]: Pin 'dut1/f4/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4407 2.59518e-05) on net out[88]: Pin 'dut1/f5/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4344 2.59518e-05) on net out[88]: Pin 'dut1/f5/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4515 2.59497e-05) on net out[80]: Pin 'dut1/f6/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4460 2.59497e-05) on net out[80]: Pin 'dut1/f6/m2/U11/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4619 2.595e-05) on net out[72]: Pin 'dut1/f7/m4/U29/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4560 2.595e-05) on net out[72]: Pin 'dut1/f7/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4731 2.59515e-05) on net out[64]: Pin 'dut1/f8/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4668 2.59515e-05) on net out[64]: Pin 'dut1/f8/m2/U3/A' is not connected to net (PARA-044)
Information: Merged 2 parallel coupling capacitors to total 6.04748e-05 pf between file nodes 'out[62]:19' and 'dut1/f9/r8:4'. (PARA-050)
Error: Invalid capacitor (*4837 2.59474e-05) on net out[56]: Pin 'dut1/f9/m4/U32/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4776 2.59474e-05) on net out[56]: Pin 'dut1/f9/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4947 2.59509e-05) on net out[48]: Pin 'dut1/f10/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4892 2.59509e-05) on net out[48]: Pin 'dut1/f10/m2/U11/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5053 2.59481e-05) on net out[40]: Pin 'dut1/f11/m4/U32/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*4992 2.59481e-05) on net out[40]: Pin 'dut1/f11/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5161 2.59522e-05) on net out[32]: Pin 'dut1/f12/m4/U32/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5100 2.59522e-05) on net out[32]: Pin 'dut1/f12/m2/U3/A' is not connected to net (PARA-044)
Information: Merged 2 parallel coupling capacitors to total 8.79513e-05 pf between file nodes 'out[29]:7' and 'dut1/f13/m1/n19:9'. (PARA-050)
Error: Invalid capacitor (*5269 2.59523e-05) on net out[24]: Pin 'dut1/f13/m4/U32/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5208 2.59523e-05) on net out[24]: Pin 'dut1/f13/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5379 2.5953e-05) on net out[16]: Pin 'dut1/f14/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5324 2.5953e-05) on net out[16]: Pin 'dut1/f14/m2/U11/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5485 2.59529e-05) on net out[8]: Pin 'dut1/f15/m4/U32/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5424 2.59529e-05) on net out[8]: Pin 'dut1/f15/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5595 2.59486e-05) on net out[0]: Pin 'dut1/f16/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*5532 2.59486e-05) on net out[0]: Pin 'dut1/f16/m2/U3/A' is not connected to net (PARA-044)
Information: Merged 2 parallel coupling capacitors to total 8.79457e-05 pf between file nodes 'clk:766' and 'kout[110]:20'. (PARA-050)
Warning: Coupling capacitor (N133:10 FE_OFN3_n10:300 0.000131916) on net N133\ is grounded because net 'FE_OFN3_n10:300' could not be found (PARA-162)
Warning: Coupling capacitor (N133:11 FE_OFN3_n10:298 0.000131926) on net N133\ is grounded because net 'FE_OFN3_n10:298' could not be found (PARA-162)
Warning: Coupling capacitor (N133:10 FE_OFN3_n10:298 0.000126428) on net N133\ is grounded because net 'FE_OFN3_n10:298' could not be found (PARA-162)
Warning: Coupling capacitor (N133:11 FE_OFN3_n10:299 0.000126428) on net N133\ is grounded because net 'FE_OFN3_n10:299' could not be found (PARA-162)
Warning: Coupling capacitor (N133:10 FE_OFN3_n10:289 5.49714e-05) on net N133\ is grounded because net 'FE_OFN3_n10:289' could not be found (PARA-162)
Warning: Coupling capacitor (N133:11 FE_OFN3_n10:290 5.49714e-05) on net N133\ is grounded because net 'FE_OFN3_n10:290' could not be found (PARA-162)
Warning: Coupling capacitor (N133:10  0.000131916) on net  \ is grounded because net 'FE_OFN3_n10:300' could not be found (PARA-162)
Warning: Coupling capacitor (N133:11  0.000131926) on net  \ is grounded because net 'FE_OFN3_n10:298' could not be found (PARA-162)
Warning: Coupling capacitor (N133:10  0.000126428) on net  \ is grounded because net 'FE_OFN3_n10:298' could not be found (PARA-162)
Warning: Coupling capacitor (N133:11  0.000126428) on net  \ is grounded because net 'FE_OFN3_n10:299' could not be found (PARA-162)
Warning: Coupling capacitor (N133:10  5.49714e-05) on net  \ is grounded because net 'FE_OFN3_n10:289' could not be found (PARA-162)
Warning: Coupling capacitor (N133:11  5.49714e-05) on net  \ is grounded because net 'FE_OFN3_n10:290' could not be found (PARA-162)
Warning: Coupling capacitor (N173:12 FE_OFN5_n11:319 0.000203378) on net N173\ is grounded because net 'FE_OFN5_n11:319' could not be found (PARA-162)
Warning: Coupling capacitor (N173:13 FE_OFN5_n11:320 0.000203378) on net N173\ is grounded because net 'FE_OFN5_n11:320' could not be found (PARA-162)
Warning: Coupling capacitor (N173:12 FE_OFN5_n11:320 3.29758e-05) on net N173\ is grounded because net 'FE_OFN5_n11:320' could not be found (PARA-162)
Warning: Coupling capacitor (N173:13 FE_OFN5_n11:321 3.29855e-05) on net N173\ is grounded because net 'FE_OFN5_n11:321' could not be found (PARA-162)
Warning: Coupling capacitor (N173:8 FE_OFN5_n11:320 7.84849e-05) on net N173\ is grounded because net 'FE_OFN5_n11:320' could not be found (PARA-162)
Warning: Coupling capacitor (N173:9 FE_OFN5_n11:321 7.84946e-05) on net N173\ is grounded because net 'FE_OFN5_n11:321' could not be found (PARA-162)
Warning: Coupling capacitor (N173:17 FE_OFN5_n11:322 5.49433e-06) on net N173\ is grounded because net 'FE_OFN5_n11:322' could not be found (PARA-162)
Warning: Coupling capacitor (N173:16 FE_OFN5_n11:323 5.50411e-06) on net N173\ is grounded because net 'FE_OFN5_n11:323' could not be found (PARA-162)
Warning: Coupling capacitor (N173:12  0.000203378) on net  \ is grounded because net 'FE_OFN5_n11:319' could not be found (PARA-162)
Warning: Coupling capacitor (N173:13  0.000203378) on net  \ is grounded because net 'FE_OFN5_n11:320' could not be found (PARA-162)
Warning: Coupling capacitor (N173:12  3.29758e-05) on net  \ is grounded because net 'FE_OFN5_n11:320' could not be found (PARA-162)
Warning: Coupling capacitor (N173:13  3.29855e-05) on net  \ is grounded because net 'FE_OFN5_n11:321' could not be found (PARA-162)
Warning: Coupling capacitor (N173:8  7.84849e-05) on net  \ is grounded because net 'FE_OFN5_n11:320' could not be found (PARA-162)
Warning: Coupling capacitor (N173:9  7.84946e-05) on net  \ is grounded because net 'FE_OFN5_n11:321' could not be found (PARA-162)
Warning: Coupling capacitor (N173:17  5.49433e-06) on net  \ is grounded because net 'FE_OFN5_n11:322' could not be found (PARA-162)
Warning: Coupling capacitor (N173:16  5.50411e-06) on net  \ is grounded because net 'FE_OFN5_n11:323' could not be found (PARA-162)
Note - message 'PARA-162' default limit (100) exceeded.  Remainder will be suppressed.
Note - message 'PARA-124' default limit (100) exceeded.  Remainder will be suppressed.
Error: Invalid capacitor (FE_OFC0_n10:A 6.78101e-05) on net n10: node not found (PARA-044)
Error: Invalid capacitor (FE_OFC4_n11:A 2.59516e-05) on net n11: node not found (PARA-044)
Error: Invalid capacitor (FE_OFC8_n143:A 2.59476e-05) on net n143: node not found (PARA-044)
Error: Invalid capacitor (*7451 2.59476e-05) on net n143: Pin 'U651/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7448 2.59476e-05) on net n143: Pin 'U648/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7447 2.59476e-05) on net n143: Pin 'U647/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7446 2.59476e-05) on net n143: Pin 'U646/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7445 2.59476e-05) on net n143: Pin 'U645/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7444 2.59476e-05) on net n143: Pin 'U644/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7443 2.59476e-05) on net n143: Pin 'U643/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7442 2.59476e-05) on net n143: Pin 'U642/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7434 2.59476e-05) on net n143: Pin 'U634/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7419 2.59476e-05) on net n143: Pin 'U619/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7417 2.59476e-05) on net n143: Pin 'U617/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7416 2.59476e-05) on net n143: Pin 'U616/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7415 2.59476e-05) on net n143: Pin 'U615/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7414 2.59476e-05) on net n143: Pin 'U614/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7413 2.59476e-05) on net n143: Pin 'U613/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7412 2.59476e-05) on net n143: Pin 'U612/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7411 2.59476e-05) on net n143: Pin 'U611/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7409 2.59476e-05) on net n143: Pin 'U609/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7407 2.59476e-05) on net n143: Pin 'U607/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7406 2.59476e-05) on net n143: Pin 'U606/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7404 2.59476e-05) on net n143: Pin 'U604/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7384 2.59476e-05) on net n143: Pin 'U584/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7383 2.59476e-05) on net n143: Pin 'U583/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7382 2.59476e-05) on net n143: Pin 'U582/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7381 2.59476e-05) on net n143: Pin 'U581/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7380 2.59476e-05) on net n143: Pin 'U580/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7379 2.59476e-05) on net n143: Pin 'U579/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7378 2.59476e-05) on net n143: Pin 'U578/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7377 2.59476e-05) on net n143: Pin 'U577/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*7375 2.59476e-05) on net n143: Pin 'U575/A1' is not connected to net (PARA-044)
Information: Merged 2 parallel coupling capacitors to total 3.77718e-05 pf between file nodes 'kout[80]:12' and 'dut1/f19/n59:6'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 3.84709e-05 pf between file nodes 'kout[56]:17' and 'kout[60]:12'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 0.000130809 pf between file nodes 'kout[15]:13' and 'kout[11]:18'. (PARA-050)
Error: Invalid capacitor (dut1/FE_OFC6_i_10:A 2.5953e-05) on net i[10]: node not found (PARA-044)
Error: Invalid capacitor (*6244 2.5953e-05) on net i[10]: Pin 'dut1/U385/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6243 2.5953e-05) on net i[10]: Pin 'dut1/U382/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6225 2.5953e-05) on net i[10]: Pin 'dut1/U328/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6208 2.5953e-05) on net i[10]: Pin 'dut1/U277/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6206 2.5953e-05) on net i[10]: Pin 'dut1/U271/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6205 2.5953e-05) on net i[10]: Pin 'dut1/U268/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6185 2.5953e-05) on net i[10]: Pin 'dut1/U208/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6157 2.5953e-05) on net i[10]: Pin 'dut1/U124/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6156 2.5953e-05) on net i[10]: Pin 'dut1/U121/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6143 2.5953e-05) on net i[10]: Pin 'dut1/U82/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6142 2.5953e-05) on net i[10]: Pin 'dut1/U79/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6141 2.5953e-05) on net i[10]: Pin 'dut1/U76/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6140 2.5953e-05) on net i[10]: Pin 'dut1/U73/A1' is not connected to net (PARA-044)
Error: Invalid capacitor (*6139 2.5953e-05) on net i[10]: Pin 'dut1/U70/A1' is not connected to net (PARA-044)
Information: Merged 3 parallel coupling capacitors to total 0.000371099 pf between file nodes 'dout[118]:16' and 'N247:8'. (PARA-050)
Information: Merged 3 parallel coupling capacitors to total 0.000182697 pf between file nodes 'kin[31]:15' and 'N169:14'. (PARA-050)
Information: Merged 3 parallel coupling capacitors to total 0.000134168 pf between file nodes 'kin[26]:17' and 'kout[69]:19'. (PARA-050)
Error: Invalid capacitor (*6664 2.59673e-05) on net kin[24]: Pin 'dut2/s4/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*6601 2.59673e-05) on net kin[24]: Pin 'dut2/s4/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*6341 2.59558e-05) on net kin[16]: Pin 'dut2/s1/m4/U37/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*6277 2.59558e-05) on net kin[16]: Pin 'dut2/s1/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*6448 2.59491e-05) on net kin[8]: Pin 'dut2/s2/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*6385 2.59491e-05) on net kin[8]: Pin 'dut2/s2/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*6556 2.59515e-05) on net kin[0]: Pin 'dut2/s3/m4/U35/A' is not connected to net (PARA-044)
Error: Invalid capacitor (*6493 2.59515e-05) on net kin[0]: Pin 'dut2/s3/m2/U3/A' is not connected to net (PARA-044)
Error: Invalid capacitor (dut1/FE_OFC9_n261:A 2.59553e-05) on net dut1/n261: node not found (PARA-044)
Error: Invalid capacitor (*6248 2.59553e-05) on net dut1/n261: Pin 'dut1/U389/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6246 2.59553e-05) on net dut1/n261: Pin 'dut1/U387/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6245 2.59553e-05) on net dut1/n261: Pin 'dut1/U386/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6241 2.59553e-05) on net dut1/n261: Pin 'dut1/U376/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6240 2.59553e-05) on net dut1/n261: Pin 'dut1/U373/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6238 2.59553e-05) on net dut1/n261: Pin 'dut1/U367/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6237 2.59553e-05) on net dut1/n261: Pin 'dut1/U364/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6236 2.59553e-05) on net dut1/n261: Pin 'dut1/U361/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6235 2.59553e-05) on net dut1/n261: Pin 'dut1/U358/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6233 2.59553e-05) on net dut1/n261: Pin 'dut1/U352/B2' is not connected to net (PARA-044)
Error: Invalid capacitor (*6215 2.59553e-05) on net dut1/n261: Pin 'dut1/U298/B2' is not connected to net (PARA-044)
Note - message 'PARA-044' default limit (100) exceeded.  Remainder will be suppressed.
Information: Merged 2 parallel coupling capacitors to total 1.71192e-05 pf between file nodes 'dut1/f1/y10:13' and 'dut1/f1/y15:8'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 7.14607e-05 pf between file nodes 'dut1/f2/m1/n15:9' and 'dut1/f2/m1/n18:5'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 2.19823e-05 pf between file nodes 'dut1/f4/m1/n15:14' and 'dut1/f4/x4:24'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 3.29758e-05 pf between file nodes 'dut1/f4/m1/n19:36' and 'dut1/f4/y11:16'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 0.00012093 pf between file nodes 'dut1/f5/y9:7' and 'dut1/f5/x2:12'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 8.79524e-05 pf between file nodes 'dut1/f6/y3:10' and 'dut1/f6/y4:8'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 0.00012643 pf between file nodes 'dut1/f6/y11:33' and 'dut1/f6/y14:21'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 5.497e-05 pf between file nodes 'dut1/f7/y16:6' and 'dut1/f7/y17:18'. (PARA-050)
Information: Merged 4 parallel coupling capacitors to total 7.10103e-05 pf between file nodes 'dut1/f10/y12:24' and 'dut1/f10/l1:22'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 0.000120932 pf between file nodes 'dut1/f10/m1/n15:6' and 'dut1/f10/y10:8'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 2.98987e-05 pf between file nodes 'dut1/f11/l3:9' and 'dut1/f11/m3/n17:7'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 6.04609e-05 pf between file nodes 'dut1/f12/l1:17' and 'dut1/f12/l3:26'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 5.49704e-05 pf between file nodes 'dut1/f13/y11:20' and 'dut1/f13/y15:14'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 3.29796e-05 pf between file nodes 'dut1/f13/y12:17' and 'dut1/f13/y14:17'. (PARA-050)
Information: Merged 3 parallel coupling capacitors to total 0.000153913 pf between file nodes 'dut1/f14/y11:21' and 'dut1/f14/y16:33'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 6.596e-05 pf between file nodes 'dut1/f15/m2/n22:33' and 'dut1/f15/x1:41'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 0.000166309 pf between file nodes 'dut1/f15/m4/n50:28' and 'dut1/b13[2]:21'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 4.85284e-05 pf between file nodes 'dut1/f16/l3:16' and 'dut1/f16/m3/n19:7'. (PARA-050)
Information: Merged 3 parallel coupling capacitors to total 0.000117038 pf between file nodes 'dut1/f16/m5/n9:20' and 'dut1/b15[5]:33'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 4.11128e-05 pf between file nodes 'dut1/f21/n51:12' and 'dut1/f21/n52:13'. (PARA-050)
Information: Merged 5 parallel coupling capacitors to total 4.57717e-05 pf between file nodes 'dut2/gw32[25]:8' and 'dut2/gw32[26]:10'. (PARA-050)
Information: Merged 2 parallel coupling capacitors to total 4.94783e-05 pf between file nodes 'dut2/s3/l3:27' and 'dut2/s3/m3/n17:14'. (PARA-050)
Report : read_parasitics /home/surya_srikar/sanjana/AES_without_countermeasure/aes_12/reports/aes1.spef
	-keep_capacitive_coupling
Design : aes_12_comp_masoleh
Version: Q-2019.12-SP5
Date   : Mon Apr 10 08:34:44 2023
        1633 error(s)
        Format is SPEF
        Annotated nets                   :         3710
        Annotated capacitances           :        59249
        Annotated resistances            :        55539
        Annotated coupling capacitances  :         4066
        Annotated PI models              :            0
        Annotated Elmore delays          :            0
